Old 08-26-2016, 02:17 AM   #41
Originally Posted by RevKen View Post
Does anyone use grease or something else on the hitch ball? Just got my Roo 21SS in January and am about to take our longest trip. I've noticed sometimes there's a loud squeak in the hitch when making a sharp turn. Is that normal or should I be putting grease on the ball?
RevKen
4.6L 2016 Tundra
'15 Roo 21SS
I use Slip Plate heavy duty dry film graphite lubricant. It is in a spray can and goes on wet but drys very fast. When dry you can handle it all you want and it will not rub off to you or your clothing. lubricates grate and it conducts electricity if you are concerned about using the ball as a ground.
https://www.walmart.com/ip/SLIP-PLAT...&wl13=&veh=sem
Hope This Helps Tim
TimVWulp is online now   Reply With Quote
Old 08-26-2016, 02:55 AM   #42
Croaker's Avatar
I use Evinrude Triple Guard waterproof grease to lube the ball and the weight distribution bars.
.....And I wear old clothes.
Croaker is offline   Reply With Quote
Old 08-26-2016, 01:32 PM   #43
Always grease tge ball. Just put a glob of axle grease on before I hook up. On extended tows I great when ever I unhook or once a week minimum My WD hitch has grease nipple in the torque bar sockets as well so I grease them each time before I put weight on them .Makes for a quiet ride and less wear.
Filterman is offline   Reply With Quote
Old 08-26-2016, 05:34 PM   #44
Hitch ball grease
Get a bright orange tennis ball, cut 1 1/2" hole in it, cut 4 short slits around hole and slip it over greased ball. It does three things, keeps ball clean, keeps grease off pants and makes it easy to see.
2016 Flagstaff 23 FB, GVWR 5385
Tundra, Double Cab, 5.7
TRD Off Road 4x4, GVWR 7200 lbs.
w/ tow package
MS Gulf Coast
Goff is offline   Reply With Quote
Old 08-26-2016, 07:31 PM   #45
Powerman's Avatar
Used motor oil from oil changes and a towel. Cheap and shiny.
MARINOS
2015 PRIME TIME AVENGER 28 DBS
2016 GMC SIERRA DENALI 2500 HD
Powerman is offline   Reply With Quote
Old 08-26-2016, 08:35 PM   #46
northstar1960's Avatar
Glad i don't need to grease my balls . sounds like a messy mess to deal with all the time . the andersen wd is lite 60 lbs and no grease ever needed .
northstar1960 is offline   Reply With Quote
Old 08-27-2016, 08:29 PM   #47
Prime Member
Originally Posted by SilverArrowPro View Post
Never, it is a grounding point for your electric, I'd rather deal with a little noise.
The hitch ball is an unreliable ground. There is slop in the receiver not to mention paint. The trailer is grounded through the wiring harness.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is online now   Reply With Quote
Old 08-28-2016, 07:18 PM   #48
I use axle grease also, just a dab before each trip.
2015 Work n Play 30WLA
2017 Ford F-350 Lariat diesel, crew cab 4x4
slapshot12 is offline   Reply With Quote
Old 08-30-2016, 08:58 AM   #49
grease
I cover thr hitch/ball with a wal mart bag while unhitched in campground.
pdqparalegal1 is offline   Reply With Quote
Old 09-02-2016, 07:23 AM   #50
bareftn's Avatar
Originally Posted by Life is great View Post
I lube a little, keeps all the noise down and wears a little less, but sucks when you bang you leg on it and get you pants/leg all greased up. Done that plenty of times.
I put a cover on my ball when not in use and no dirt sticks to ball, if you bang your shin the first time it hurts and their should never been a next time it took me several and now I always look, its been years since I hit mine. When in garage or camping I have a small traffic cone I put behind mine and why people think they don't need grease on theirs just show me where steel on steel grinding away has now wear and friction, you may not see it but making turns will put pressure on the ball hitch and trailer hitch
bareftn is offline   Reply With Quote
hitch
