Old 04-18-2016, 07:38 PM   #1
Jimsue's Avatar
Lug nut cover removal
I was trying to remove my Lugnuts covers so that I could check the torque on my saber tires. There does not seem to be an obvious way to remove these covers and I was wondering if anyone out there could tell me a simple technique for removing the covers without marring them? Thanks in advance for any help that can be offered.
I tried this tool but it was way too big…Click image for larger version
Name:	ImageUploadedByForest River Forums1461022669.826666.jpg
ID:	105371Click image for larger version
Name:	ImageUploadedByForest River Forums1461022694.728664.jpg
2015 F350 Lariat Crewcab DPS SWD 4x4
2013 Sabre BKOK 31
Demco Hijacker Autoslid
Renogy Solar Suitcase
Progressive Industries EMS
Sea Eagle 420 Tandem Inflatable Kayak
Jimsue is online now   Reply With Quote
Old 04-18-2016, 08:58 PM   #2
ddphillips52's Avatar
The covers on mine don't come off. Just use the appropriate size socket on them the same as you would with a bare nut.
Dennis, Linda, and Scout the Dog
2015 Mesa Ridge 347 RES
Husky 16KW with Reese Sidewinder
2013 4WD RAM 3500 Cummins TD SBCC
ddphillips52 is offline   Reply With Quote
Old 04-18-2016, 09:07 PM   #3
clr
There is no cover for the acorn lug nuts. You should find out what size socket you need mine are 7/8 inch but I have 7K axles and 8 lugs. They make a deeper special socket for acorn lug nuts for mag wheels. You can get this type socket from an auto zone or similar type of store. I always carry the proper socket in my truck because the tire service guys do not seem to bring the proper socket with them.
clr is offline   Reply With Quote
Old 04-18-2016, 09:26 PM   #4
Jimsue's Avatar
Thanks...maybe my socket was not deep enough. Because when Placed it over the lugnut, it just spun. Upon closer examination, it appears that the nuts are plastic, so I assumed they are covers....74 inch or 19 mm...I'll check my other socket tools tomorrow and make sure it's deep enough.
Jim.couillard at gmail
F350 lariat diesel
2013 Sabre 5th Wheel 31 RKOK-6
Demco Hijacker Hitch
2013 Sabre BKOK 31
Old 04-18-2016, 10:41 PM   #5
clr
I have never seen any with plastic covers but never say never I suppose. The ones I have seen are thin metal that is hollow and formed like a longer nut but the lower section in a rather normal lug nut that the hollow cover attached to but the cover is not meant to be removable. That is why the proper socket is required to be able to get down on to the nut portion to remove and install the wheel. If you have a socket that is not deep enough you will just deform the thin metal and destroy the acorn nut.
Old 04-19-2016, 07:42 AM   #6
Jimsue's Avatar
Thank you, Cir! That makes sense...looks like it's time for a trip to Napa ( not the Valley, unfortunately) for a deep socket.
2013 Sabre BKOK 31
Old 04-19-2016, 12:57 PM   #7
mike.t's Avatar
They make sockets to prevent marring a lug nut.
protective lug nut socket | eBay
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 04-21-2016, 12:46 PM   #8
Jimsue's Avatar
Thanks so much to everyone who advised me...I found a 19mm deep socket at NAPA that works perfectly. Glad I didn't wait until I was broken down on the side of the road to find out that I didn't have the right socket! 🙄🙄🙄🙄🙄
2013 Sabre BKOK 31
cover
