Old 10-07-2012, 01:57 PM   #1
dretired's Avatar
Max 5th wheel for my truck ?
What should be the Max 5th wheel.. that we should consider.. if we upgrade in the near future? The tv is a 2012 F250 diesel supercab 4x2..3.31 rearend..we now have a 2 slide -out 5th wheel... thinking of going to a 3 or 4 slide out unit
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
Old 10-07-2012, 03:25 PM   #2
Dave_Monica's Avatar
Your limit will be defined by pin weight not total camper weight. If you haven't already, take your truck to set of scales loaded ready to camp full of fuel, passengers and gear. The payload (pin weight) limit will be the trucks GVWR less the actual loaded weight. You can also determine payload (pin weight) limit by rear axle weight rating (RAWR) verses actual rear axle weight.
Your truck is rated to pull 16000? lbs but will be limited to a pin weight of around 2000 lbs (by GVWR). Using 20% pin weight, that a 10000 lb 5th wheel. If you use the RAWR, the pin weight limit would be probably be above 3000 lbs. Your choice...
Dave
Old 10-07-2012, 06:06 PM   #3
dretired's Avatar
Dave
still trying to understand this ... if the GCWR according to the Ford Guide Is 23,500 lbs and my truck loaded "ready to camp" would weigh say... 8,500lbs. Wouldnt that be the weight it ( the F250) can pull ?? and ..according to the Ford guide i have a Payload capacity of 3,000 lbs..
Old 10-07-2012, 07:12 PM   #4
FYI
Fifth Wheel Weight Calculator
Just my opinion I would be a little Leary of the rear axle ratio you have. Perhaps you'll get more comments on that issue.
grayfox is offline   Reply With Quote
Old 10-07-2012, 07:24 PM   #5
AquaMan's Avatar
I started to weigh in on this conversation, but at the risk of starting a huge debate, I decided to offer only this advice. Buy what you are comfortable towing and what you feel is within your truck's specs. I have a 2500HD and tow 14K+ and don't give it a second thought.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 10-07-2012, 08:57 PM   #6
As I'm trying to explain, the issue isn't the amount of weight you can pull, it's the amount of weight that the truck can carry.
The Ford payload guide is useless, that why you should weigh your truck ready to camp. Then you decide if you want to set your pin weight limit based on the truck's GVWR or it's RAWR.
Your truck has a GVWR of 10000 lbs but weighs around 8000 lbs ready to camp and therefore a pin weight of 2000 lbs would be at the GVWR for the truck. Most use the rear axle weight rating of the truck which would allow a pin weight of at least 1000 lbs more.
Again, your choice of which limit to use...
Dave
Old 10-08-2012, 07:37 AM   #7
dretired's Avatar
[QUOTE=Dave_Monica;261690]As I'm trying to explain, the issue isn't the amount of weight you can pull, it's the amount of weight that the truck can carry.
Well according to the "Ford specs" Column... My truck would have a rear axel rating of 6,200 lbs..SO .. what... do i add or subtract from that amount ?? ..and according to the "payload selector " it seems my truck is actually rated for 3,900 lbs
Old 10-08-2012, 07:43 AM   #8
dretired's Avatar
Originally Posted by grayfox View Post
FYI
That rear axel that i have... is giving me excellent fuel economy ( when not towing )... 25 mpg and up ...at speeds between 40 and 55 mph..Towing mpgs at around 15 mpg average.. so far.. only have 4,000 miles on this truck at present..
Old 10-08-2012, 08:09 AM   #9
It sounds like you have already made your mind up.Just do what feels right for you and the safety of your family and others. IMHO I would not push the truck to far over the MFGS. recommendations. As far as fuel economy, yours it's fantastic. I prefer a rear axle ratio of at least 3.73 I think the truck works much easier for me... less strain on OLD MAX when towing and decent fuel economy towing. Since OLD MAX is not a daily driver it works for me.
The other thing did you mention the loaded weight of your coach ? I may have missed it. Again do your homework and do what feels good for you. Just my OPINION.
Old 10-08-2012, 08:16 AM   #10
Herk7769's Avatar
I have a 2008 GMC Sierra 2500HD Crewcab with Duramax diesel (Allison Transmission) and my truck is at its max gross weight (9300 pounds) with a 9100 pound 5th wheel on its back. With hitch, generator, 10 gallons spare diesel, and family the 7800 pound curb weight empty catches up to GVWR pretty fast.
Remember a 15th wheel requires a pin weight of 15-25 percent (20 percent optimum handling) of the the total loaded camper weight for safe towing.
A 10,000 pound 5th wheel will have a pin weight range of 1500 - 2500 pounds
A 15,000 pound 5th wheel will have a pin weight range of 2250 - 3750 pounds
Optimum pin load will be in the middle of those ranges.
Newer 2500HDs will have an almost 1000 pound higher GVWR due to a frame change in 2010 (From a "C" frame to a "BOX" frame similar to their 3500).
HAM CALLSIGN - KC3FFW
5th wheel
