Old 08-22-2016, 06:03 PM   #101
danielabram71's Avatar
Ok I did a little checking on my way home from work today. I decided to watch my trans temp on the way home with nothing in tow. This is what it got up to
Name:	ImageUploadedByForest River Forums1471903355.486285.jpg
ID:	118147 I was so shocked
1014 1500 GMC
2015 solaire 267bhsk
danielabram71 is offline   Reply With Quote
Old 08-22-2016, 06:23 PM   #102
raspivey's Avatar
That may be a bad sensor. I ran about 192 pulling with 95 degree outside temp about a month ago. Otherwise, I'm well below 160.
2012 Chevy Tahoe LTZ - HD tow package
Old 08-22-2016, 06:29 PM   #103
2007 WildCat 32QBBS
05CrewDually's Avatar
Attachment 118147 I was so shocked
1014 1500 GMC
Let it sit 24 hours. Then before starting, compare 3 temps.
1. Ambient air
2. Engine Coolant Temp.
3. Automatic Transmission Temp
They all should be within a few degrees Fahrenheit.
05CrewDually is offline   Reply With Quote
Old 08-22-2016, 06:40 PM   #104
Flybob's Avatar
The highest mine has ever been is 197 and that was after jockeying into a tight site after driving for 2hrs on a 90 degree day.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-22-2016, 07:04 PM   #105
Oh yes I forgot to put the temperature outside was 71. Eng. temp was about 210 or so
1014 1500 GMC
Old 08-22-2016, 07:08 PM   #106
raspivey's Avatar
Yeah...that seems much too high. I normally see about a ten degree increase through town at slower speeds but, after an hour or so of highway, back down in temp. I agree, let it get cold and compare all the temps.
Old 08-22-2016, 07:22 PM   #107
Members
Tommy Joann's Avatar
Mine runs between 192 and 199 when towing.
2015 Flagstaff 8528CKWSA Diamond Package
2015 Chevy Silverado Crew Cab LT
Husky 16K W Hitch w/ Husky 10-16 Composite Glider
Reese Revolution Pin Box
Tommy Joann is offline   Reply With Quote
Old 08-22-2016, 07:29 PM   #108
TsnTexas's Avatar
Maybe someone addressed this already, but I'm wondering at what temp. does the transmission fluid begin to break down. Going over Wolf Creek Pass in Colorado I watched my fluid climb to 207 degrees and am wondering if I should go ahead and replace it? Normally runs about 160 on a hot day in Texas.
2016 Rockwood 2504s
2016 Chevy 2500HD
TsnTexas is offline   Reply With Quote
Old 08-22-2016, 07:36 PM   #109
raspivey's Avatar
I think it was mentioned...over 270 ish if I'm remembering right. I was running up I45 out of Houston last year and my outside temp was showing 104. Trans actually got up to about 208. I believe there is a trans overheat light but it never came on. It felt like it was starting to slip a little so I pulled over and cooled it down. My rule has become change it if it goes over 200 for more than about 30 min. just to be on the safe side.
Old 08-22-2016, 08:03 PM   #110
My truck is a 2014 I bought it when it had 400 miles on it. It has done this the whole time I have had it. Believe it or not that is about the same as when I row the camper. A guy at a KOA told me one day that it has a 195 degree thermostat in it and that is why. I have no idea my first GMC ever
1014 1500 GMC
transmission temperature
