Old 08-14-2015, 10:36 PM   #51
My 2014 Tahoe has super cooling with a big tranny and oil cooler, and the tranny runs about 175-180 during the summer heat down the highway (a lot cooler during cooler weather) and 190-192 while towing our SolAire 20RBS. Crossed southern New Mexico from Alamogordo to Las Cruces through White Sands in 105 degree heat in June. Things didn't start heating up until we started climbing San Augustine Pass. I turned off the A/C and temps dropped like a stone. It was a bit stuffy when we hit the top but temps were good.
I always change the fluid when it starts to darken; it should be a pale pink when fresh and in good condition. Tranny fluid is a whole lot cheaper than a new tranny.
elchilero53 is offline   Reply With Quote
Old 10-24-2015, 11:31 AM   #52
Retusps's Avatar
Trans cooler and temps
I have '06 GMC Sierra 1500 Z71 4x4 with tow pkg. I don't have tranny temp gauge. Any help with adding one? Thanks.
No matter where you go, there you are!
2006 GMC Sierra CC 1500 Z71
2014 Palomino Solaire Eclipse 297rlds
Husky Centerline w/d hitch
Retusps is offline   Reply With Quote
Old 01-21-2016, 08:23 PM   #53
Retusps's Avatar
Thread Killer!
Man, can I kill a thread or what
Old 01-21-2016, 09:27 PM   #54
TURBS's Avatar
Add an auto meter mechanical trans temp gauge and sender
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-24-2016, 11:12 AM   #55
Check into a Edge insight a little pricey, but you can monitor much more that trans temp with one.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 01-24-2016, 11:59 AM   #56
I can think of several recent threads on the forum where your posting would have been appreciated.
2015 Shamrock 231KSS, Oyster shell
2016 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping in 2015, 45 in 2016
CNYCamper is offline   Reply With Quote
Old 01-26-2016, 10:12 PM   #57
Retusps's Avatar
Thanks CNYCAMPER
Old 01-26-2016, 10:32 PM   #58
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
Being a first-time diesel owner [2013 Chevy Duramax/Allison 2500HD], I saw 215* for tranny temp on my Bullydog tuner. Not knowing the max temp, it scared the hell out of me. We were pulling up a 6%-14% grade with very little relief and no pullover sites. Had me sweating big time! Called my dealer and he told me about the warning coming on at 250*. Until that time, I didn't even know about a warning, much less the max temp. Never saw it in the manual and I read that thing cover to cover several times.
It generally runs around 155-175 on low hills and flat land.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 01-28-2016, 02:27 AM   #59
2007 WildCat 32QBBS
05CrewDually's Avatar
You can get a ScanGaugeII @ Advance Auto for around $150. Order it online and use promo code TRT30 to get a discount and pay only $111.99.
It will read not only Trans temp but practically every other sensor on the powertrain. It can also check for codes.
Below is a picture of it's display. Simple one plug hook up to the OBDII port under the dash.
http://shop.advanceautoparts.com/web...151&taskType=A
05CrewDually is offline   Reply With Quote
Old 01-28-2016, 01:20 PM   #60
buckaroo2's Avatar
Thumbs up
Did i miss something here ??,Are we talking about the gas transmission or the duramax allinson trans mission which i believe are a lot tougher than the gas model trans I have a new 2015 duramax allinson tranny now you have me curious to lookaat my manual to see what max temp will be . as I just got this truck and have not towed with it , until i pick up our 36ckts in the spring
buckaroo2 is offline   Reply With Quote
transmission temperature
