Old 02-01-2016, 08:42 PM   #61
Retusps's Avatar
Originally Posted by 05CrewDually View Post
You can get a ScanGaugeII @ Advance Auto for around $150. Order it online and use promo code TRT30 to get a discount and pay only $111.99.
It will read not only Trans temp but practically every other sensor on the powertrain. It can also check for codes.
Below is a picture of it's display. Simple one plug hook up to the OBDII port under the dash.
Advance Auto Parts: Shopping Cart
WOW !! Good call on the ScanGauge II! So much easier than the route I was thinking about, and it shows so many other readings besides the one I was after. Advanced Auto matched the $111.99 online price out the door, no waiting by the mailbox! Thanks for your help.
No matter where you go, there you are!
2006 GMC Sierra CC 1500 Z71
2014 Palomino Solaire Eclipse 297rlds
Husky Centerline w/d hitch
Retusps is offline   Reply With Quote
Old 02-01-2016, 08:56 PM   #62
Who Dares, Wins
doc73's Avatar
Originally Posted by buckaroo2 View Post
Did i miss something here ??,Are we talking about the gas transmission or the duramax allinson trans mission which i believe are a lot tougher than the gas model trans I have a new 2015 duramax allinson tranny now you have me curious to lookaat my manual to see what max temp will be . as I just got this truck and have not towed with it , until i pick up our 36ckts in the spring
Back 900 pages or so.. I think it was for gas. But wither way it is a good resource.
I was interested to see the 215 on the Durmax.. Mine never got above 170 in the mountains, but good to hear the max temp to look out for.
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon
2015 ChevyHD D-Max
2014 Greywolf 26DBH
doc73 is offline   Reply With Quote
Old 02-01-2016, 10:32 PM   #63
2007 WildCat 32QBBS
05CrewDually's Avatar
Excellent. You can use that promo code all the time on other products and pick them up in the store. I do it all the time.
I'm guessing you found the ScanGauge website with the listing of X-gauges that you can enter in? You can also piggy back them for 8 display.
It's a priceless piece for guys like me running a Ford 6.0 diesel. Oil/water temp delta is a biggy.
05CrewDually is offline   Reply With Quote
Old 02-03-2016, 10:40 PM   #64
Retusps's Avatar
Yes, I found the X-gauge codes on the website. I'm not sure what you mean by piggy backing for 8 display. Sorry, I'm from the age where you drill a hole in the pan and stick a sending unit in it and run a wire up to the dash and attach it to a cheap gauge. I put it in my GMC 1500 gasser to monitor the tranny temps while towing. I can't find the oil temp on mine, computer must not register oil temp. It's a great tool just the same. Thanks for sharing your knowledge!
Old 02-03-2016, 11:00 PM   #65
2007 WildCat 32QBBS
Piggyback or daisy chain I mean you can hook 2 together with an additional cord so you don't have to scroll through to check other readings. In essence you have 2 live displays coming from the one OBDII port.
So, what kind of trans Temps are you seeing?
Old 02-03-2016, 11:34 PM   #66
acadianbob's Avatar
I've been using ScanGaugeII for 10 years. Very useful device.
http://i421.photobucket.com/albums/pp297/acadianbob/IMG_2757.jpg
2012 F150 FX4 Ecoboost, 2016 Surveyor 274BHS
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 02-04-2016, 05:59 PM   #67
Retusps's Avatar
Thumbs up
I'm following you now! I don't need to see 8 readings at once, so I'll just use it as is for now. As far as temps go, it's been between 98 to 130 degrees not towing. Cold weather here in K.C. keeping it down I think. I'm not sure what max temp should be for it either. Any idea?
Old 02-04-2016, 10:14 PM   #68
Who Dares, Wins
doc73's Avatar
250 (might be 230) I think. My 1500 would get to 205 at its highest when towing.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2014 Greywolf 26DBH
Old 02-04-2016, 10:29 PM   #69
2007 WildCat 32QBBS
GCVW ambient air temp, and hills will all play part but on flat land towing with my Ford it's around 165-180. Pulling long 8% grade it will creep up around 200+. Keep it below 230 for any extended time and your fine.
Old 02-04-2016, 10:47 PM   #70
duramaxlbz's Avatar
Best thing to monitor your truck is a CTS 2... but for the Allison 100 above outside temp. But you don't want her to get over 230 pulling a hill. Your clutchs will hate you and it might Limp the tranny
duramaxlbz is offline   Reply With Quote
transmission temperature
