Old 06-01-2013, 06:22 PM   #1
Max Pin Weight???
I have a 2012 GMC 2500HD short bed SRW with the Duramax Allison combo with Michelin rubber. What is the max pin weight I can safely put in my truck? My current 2009 Wildcat 31TS 5vr weighs #9850 and a pin weight of #1970. I am thinking of stepping up to a Fuzion Toyhauler that weighs #12500 and pin weight of #3000. Is this too much or am I being a worry wart?
Wilson1970 is offline   Reply With Quote
Old 06-01-2013, 06:27 PM   #2
jtstromsburg's Avatar
Your doorpost should State gvwr. Weigh your truck, ready to camp, and see what the difference is. That is you're pin capacity. But, a 3K pin weight, will be too much for a 3/4T. Heck, that's more that most duals have left after passengers and gear are stowed in the truck.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 06-01-2013, 08:17 PM   #3
I have a 3500HD Ext Cab Long-Bed 2WD SRW and it has a CCC of 3875. I still have to take passengers, cargo, 5er-hitch out of that.
Your 2500 probably has about 1000# less.
Old 06-01-2013, 10:45 PM   #4
Fulltime family RVer
^^^ this. You need to load the truck up like you're going camping and get to a scale to find out real world weights that are specific to you, your family and your truck. Anything else is guessing.
ependydad is online now   Reply With Quote
Old 06-02-2013, 07:41 PM   #5
jevanb's Avatar
I am sitting at 2500lbs pin and I only sag 2 inches to level
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 06-02-2013, 10:39 PM   #6
That is too much weight for your truck. I too had a 12' model with a D/A and it had a 10k GVWR, my truck with a full tank of fuel and just me pinged in on the scale at 7800#. So that left 2200# left for pin weight, cargo and passengers. Now if your a person that will run over the GVWR and go to the axle rating I think you would still be VERY close.
Since I too was committed in getting a larger toy hauler I sat back and determined that a larger TV was in order and THEN I was able to match my T/H to my truck. Because I bought a DRW D/A I pretty much picked anything I wanted and didn't fear an overload situation.
Good luck
Leroy2u is offline   Reply With Quote
Old 06-02-2013, 11:15 PM   #7
Denver, CO
garbonz's Avatar
30 ft vcross, 9200 lbs, 2200 pin and I am already 460 over GVWR. I need to shift a bunch of weight from the truck and the front of the camper and put it on the rear rack, and carry less. You'll never make it.
On the other hand, I am we'll under GCWR, Trailer GVWR and both TV axles.
Report
TV Weight W/ Trailer Attached: 9660
TV Weight: 7440
Trailer Kingpin Weight: 2220
Trailer Gross Weight: 9280
TV & Trailer Combined Weight: 16720
Vertical Load (Kingpin): 24%
Safety Margin VS. Overload
TV Front Axle Weight: -470
TV Rear Axle Weight: -624
TV Gross Weight (GVW): 460
TV Combined Weight (GCW): -5280
Hitch Tow (GTW): -8720
Vertical Load (Kingpin): -2280
Trailer Gross Weight (GVW): -670
2017 Fuse 23T
Old 06-02-2013, 11:17 PM   #8
Denver, CO
garbonz's Avatar
How does sag enter into the equation? What is the sag spec?
2017 Fuse 23T
Old 06-03-2013, 06:57 AM   #9
I wonder the same as my DRW sags 2 1/2" in the back with 2300 pounds of pin weight set onto it.
