Old 08-21-2016, 03:31 PM   #11
My bad. I now see where you said you were upgrading the 3.73 to 4.3. That is a big difference in the weight allowance. I too, would like a 4 season toy hauler, but most of them are in the 14000+ range. And the problem with the light weight toy haulers, is that thet aren't built or warrantied, as a 4 season, full time living, RV
RickyD929 is offline   Reply With Quote
Old 08-21-2016, 04:55 PM   #12
Originally Posted by RickyD929 View Post
Where are you guys getting this 15000 lbs at, for the F250 towable weight? I've got a 2014 F250, and it's only rated for 12500. With the same 373 gears. This 12500, is also from Ford, per theit towing chart
Here :
http://www.ford.com/resources/ford/g...tyPU_Sep30.pdf
2015 Work n Play 30WLA
2015 Ford F-250 Lariat diesel, crew cab 4x4
slapshot12 is offline   Reply With Quote
Old 08-21-2016, 05:00 PM   #13
Originally Posted by ccsvolsfan View Post
Another way to determine if your truck will safely pull a given 5er is to ask a salesman at RV dealership. They are very knowledgeable about such things. ��������������
LOL, sadly that is true. If it were up to most of them, we'd be towing 42 footers with an F-150. I actually heard a salesman tell a guy once, "you have the max tow package, you can tow anything on this lot." When I saw the guy alone later, I said look closely at your owners manual, an F-150 won't go much over 9-10K if you're lucky.
Old 08-21-2016, 05:29 PM   #14
Exactly. The 09 F150 I had, with tow package, was rated for 8200 lbs. But yet these manufacturer's keep advertising these half ton 5'ers. Half the F250's running up and down the road are towing more than the 12500, that they're rated for.
Old 08-21-2016, 08:47 PM   #15
Gross Combined Weight Rating
GCWR.....GCWR.....GCWR
Weight it....Know it.....Don't overload it
You will pay a fine, one way or another.
Jesse
2016 F450
2017 Cedar Creek 38EL Champagne
Only here once - do it baby!
Jesse is offline   Reply With Quote
Old 08-21-2016, 10:39 PM   #16
mbbutler's Avatar
F350 has an extra leaf spring in rest
mbbutler is offline   Reply With Quote
Old 08-21-2016, 11:37 PM   #17
CaptnJohn's Avatar
More often those 5ers are putting any 3/4 ton truck over payload, especially those with a diesel. Payload is the only reason I traded up to an F350. The axel ratings are close on many as well. My F250 did the job ~~ excelled even. The payload number had me uncomfortable and watching my load. No longer concerned, added a 2nd battery and if my wife decides on the washer/dryer there will not be a 2nd thought.
Old 08-22-2016, 09:41 AM   #18
Without specific details, your statement isn't true.
For the past few years, the F250 and F350 (SRW) are identical except for the blocks.
Same spring pack, same overload, same rear end, same axles... etc.
325BH is offline   Reply With Quote
Old 08-22-2016, 09:54 AM   #19
Zoom's Avatar
Not real scientific but compared my 3 month old f250 diesel with a f350 that was on the dealer lot and the f350 had an extra spring that I would call an overload spring in the past.
2015 XLR 29HFS Toy Hauler
2016 Ford F250 Lariat Crew Cab FX4 Power Stroke
2007 Harley Softail Deluxe
2005 Victory Vegas
Zoom is offline   Reply With Quote
Old 08-22-2016, 09:56 AM   #20
OntarioFireFighter's Avatar
Without knowing how the trucks were optioned; something like one having the camper package, and one not; would explain the different spring configurations...
All things being equal, the difference is a 2" block vs. a 4" block; and the sticker...
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2015: 37
Nights Booked 2016: 44
Nights Camped 2016: 41
OntarioFireFighter is offline   Reply With Quote
f250, fifth wheel, towing, toy hauler, wheel
