Old 04-07-2013, 10:06 PM   #11
Steve7575's Avatar
Yes, Maxxis have 14" tires. Just had 14" Maxxis tires installed on my enclosed tandem axle trailer. I went with them due to comments on other forums I frequent..
Steve7575 is offline   Reply With Quote
Old 04-07-2013, 10:51 PM   #12
PPST OGCDG
Frank-VA's Avatar
Originally Posted by schrederman View Post
Do they make 14" tires?
Here is a web site for Maxxis Tires
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
Old 04-08-2013, 01:29 AM   #13
Put Maxxis tires on our TT back in Feb and like them. They ride much better than the stock tires. I paid for stems and balancing but the tire buster was not wanting to deal with it. He did it anyway after giving me some bs. I have used this local tire shop for many years, no more.
2004 F150 4.6 Griffin tuned
2010 Wildwood 24FBS
johnleann is offline   Reply With Quote
Old 04-08-2013, 04:03 AM   #14
wmtire's Avatar
Yes they do, but only as high as a Load Range C (6 ply rated).
M8008 ST Radial
If you want Load Range D (8 ply rated), in a 14 inch tire, it's easier to find what we call Euro Tires.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 04-27-2013, 08:19 PM   #15
jlgail4309's Avatar
Is that a speed rated to 75 miles per hour.
2008 Jeep Grand Cherokee Diesel
2013 Salem Cruise light 19bh
Hensley Cub hitch ,
jlgail4309 is offline   Reply With Quote
Old 04-28-2013, 06:37 AM   #16
Herk7769's Avatar
Goodyear Marathons and other ST tires (I would bet) will benefit from the information in the attachment from Goodyear.
Basically, ST tires are speed rated at 65 MPH; BUT if you have the excess load capacity, you can adjust the inflation pressure upwards by up to 10 PSI over the required pressure for your load (also within the capability of the rims) to add up to 10 MPH to the speed rating.
For example, if your camper came with MAXXIS ST225/75R15 C rated tires and when you hit the scale your camper's load on each tire was 2000 pounds. At 2000 pounds of load (according to the Maxxis chart) your "correct 100% inflation pressure" would be 45 PSI and not the maximum inflation pressure of 50 PSI.
In the above scenario, running your MAXXIS ST225/75R15 C rated tires at 50 PSI at the 2000 pound load would increase your sped rating to 70 MPH.
It would be impossible to increase the speed rating above 70 MPH in this case without up grading your tire range to "D" in order to use a higher than C rated inflation pressure of 55 PSI. If you bought 4 of the D rated MAXXIS ST225/75R15 tires, and ran the pressure at 55 PSI with a 2000 pound loading you would achieve the best case speed rating of 75 MPH. (A 10 MPH boost for every PSI above that required to carry the load.
This only works if you have the load and pressure data for your tires AND KNOW the actual load on your camper's tires (get weighed and weigh each axle's load; not both and divide by 4 as the rear axle may be carrying more of the camper's weight than the front if the camper is not exactly level when connected).
HAM CALLSIGN - KC3FFW
Old 06-11-2013, 05:13 PM   #17
Batts-toy's Avatar
I have been out only 1 time with my 26TBSS and the way the 205/75R15 C rated tires felt while towing made me very nervous so I got the weights taken and am at 7080 pounds TT. Went straight to Americas Tire and ordered Maxxis M8008 225/75R15 and new equally rated wheels as well. Came home and read your advise on the metal valve stems so I called the sales person back, he said he has the high pressure metal stems in stock and their company policy requires these on the E rated tires I ordered so we're all set. I am fairly new to the forum and appreciate all the great advice you provide, whenever I see your name I make sure to read your comment very closely.
Thanks again
Dale and Terri
2013 Tundra 4X4 TRD Offroad
2013 Wildwood 26TBSS
and yes all my weights are well within the TV limits.
Batts-toy is offline   Reply With Quote
Old 06-11-2013, 09:13 PM   #18
schrederman's Avatar
My original TowMax tires are apparently not very good. I was inspecting the trailer after a trip and discovered the tread bulging on one for about 1/3 of the circumference. I got a Maxxis to replace it. I will probably replace the other 3 soon as it's gonna be time to replace the tires on both our vehicles. I'll see what kind of deal I can get buying 11 tires from the same guy... Yeah... I'm cheap!
I haven't seen a negative post about Maxxis, and I haven't seen many positive posts about any of the other brands, including Goodyear...
+1 on Herk's advise. I haven't seen him post anything I haven't agreed with, on a common-sense level...
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 06-11-2013, 09:38 PM   #19
...I haven't seen a negative post about Maxxis, and I haven't seen many positive posts about any of the other brands, including Goodyear...
Have run GY Marathons since 1976 and have never had a problem with them. Just took a set off that were 16 yrs old that that had been on our race car trailer that set on dirt and had dry rotted so bad the tread literally fell off 2 of them and they still had 40# of air in them. Trailer was towed loaded from Anchorage, Alaska to Concord, NC when the tires were 10 yrs old. Wouldn't have anything but GY Marathons from my 37 yrs experience with them.
Old 06-12-2013, 12:11 AM   #20
wyo700's Avatar
Thanks again
Dale and Terri
Are you happy with the performance of your tundra. I know I sure am. I was really surprised how much better it pulls than my old Titan. The gas milage sucks but the power is amazing. It's nice to be able to keep my speed even in a head wind.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
