Old 02-20-2013, 10:27 PM   #1
wyo700's Avatar
Maxxis tires
Got income tax and just went and paid for some maxxis m8008 st205/75/15 load range d tires for my toy hauler. The currant tires only made it through one season. Probably could get a couple more trips out of them but I'm not willing to take that risk. But who has these maxxis tires. Do you like them how have they been. They seemed to be a very popular choice and got them paid for now so I don't miss out on them.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is online now   Reply With Quote
Old 02-21-2013, 07:38 AM   #2
Now a "Top Member"
EdJunior's Avatar
I replaced my tires with Maxxis. Have only had the camper out a couple of times with them so far, but so far so good. By default, they have to be better than the originals...IMHO.
Ed and Sharon
2010 Wildcat 28RKBS
2011 Ford F-250 XLT, 6.7L PSD
Ride-Rite Airbags and Airlift wireless remote compressor...nice!
Old 02-21-2013, 07:46 AM   #3
Herk7769's Avatar
MAKE SURE the folks who mounted your tires changed the stems to high pressure metal stems. They will not normally do that unless you tell them to.
Tire Tech Information - Tire Valve Types, Components and Uses
Most standard rubber based stems are only good for a maximum of 65 PSI with no side loads. If you use a valve mounted TPMS, the weight of the monitor can bend the stem up against the rim, causing air to leak at the base of the valve.
HAM CALLSIGN - KC3FFW
Old 02-21-2013, 07:57 AM   #4
Good advice. We switched to Maxxis, going from load range C's to D's, put on the metal valve stems, and had the tires bead-balanced. So far, so good.
bakken is offline   Reply With Quote
Old 02-21-2013, 07:58 AM   #5
PPST OGCDG
Frank-VA's Avatar
We have Maxxis tires with metal valve stems. I have not had any problems.
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
Old 02-21-2013, 09:43 AM   #6
wyo700's Avatar
Haven't had them mounted yet herk camper still got snow drifts around it. But to make you happy I did tell them to get me metal stems. The shop I got my tires from is a local mom and pop type shop that I worked at for four years between high school and college still the same owner. I have nothing but confidence in them.
2013 Toyota Tundra
Old 02-21-2013, 10:20 AM   #7
Helmsey's Avatar
On my previous TT i put Maxxis tires on it and did not have any problems with them. If I stay with a 15" tire on my current 5er it will be Maxxis LR E tires.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 02-22-2013, 10:59 AM   #8
I have that size tires on my 5er and if I were to replace them, I will move up from the D to E if I could and also metal valve stems.
whj77372 is offline   Reply With Quote
Old 04-05-2013, 04:55 PM   #9
wyo700's Avatar
Well I had my new maxxis tires put on today. When the old tires were coming off the rims I was comparing the two and wow what a difference. I had metal valve stems put in. Actually two of the old tires were separated one was really bad. It had completely separated I am lucky I even made it down there without it coming apart and it was just a short drive. But I am much happier now and ready to get to camping.
2013 Toyota Tundra
Old 04-07-2013, 09:46 PM   #10
schrederman's Avatar
Do they make 14" tires?
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
