Old 06-18-2014, 12:48 AM   #1
Terier's Avatar
MH towing Jeep - is this normal?
I'm curious...
While on the freeway today I was nervous being behind a motorhome that was towing a Jeep with all 4 wheels on the pavement. The Jeep and the back end of the MH was all over the lane the whole time. After I switched lane I could see the Jeep drifting side to side with the MH rear following but not so much the front of the MH. It was strange to watch.
Is this normal when towing with MH?
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
Old 06-18-2014, 05:21 AM   #2
RSchleder's Avatar
NO!!!!! Something was wrong with the tow setup. We've towed several vehicles behind our 3 diesel pushers and the TOAD was rock solid behind the coach. There should be no side to side (whipping) movement at all when you have the proper tow plate on the TOAD and a good, well designed, name brand tow bar!
RSchleder is offline   Reply With Quote
Old 06-18-2014, 05:24 AM   #3
Plain Old Member
Very normal to see a Jeep as a toad, 4 wheels down. We towed a Honda Fit with both our motorhomes, and it tracked really well. I've seen a lot of Jeep Wranglers and such around us behind the MH's. Not sure why his rig was swaying all over the road though. Probably, driver induced, but may have had other unknown issues. Normally 4 down will track really well.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 06-18-2014, 06:37 AM   #4
Arefbee's Avatar
I see Jeep toads pretty often without issues. It could have been road induced, but the Jeep may have been the source of the issue as well if it was badly aligned or had one or two soft tires.
Was it a Class A or a Class C motorhome?
2011 PrimeTime Tracer 2600rls
Arefbee is offline   Reply With Quote
Old 06-18-2014, 06:44 AM   #5
Engineer of Crazy Train
ChooChooMan74's Avatar
From my racing days (many years ago, so this is coming from the archives of what is left of my brain), if it is an alignment issue, there could not be enough caster or there is too much tow in. Caster, as the name applies, helps keep the wheel straight. Just think of a caster on a shopping cart that is working properly. It stays straight in the direction of travel. For too much tow in, it makes the vehicle dart left and right. Think of the wheels like / \ and if one wheel gets more traction (bump) over the other, it will dart in the way that wheel is turned. I had that issue with my Jeep, as the alignment went out this winter. Now that it is aligned, it tracks straight.
Now, since I know nothing about tow bars, maybe it could be a bad tow bar setup. But others will have to chime in.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 06-18-2014, 12:15 PM   #6
Terier's Avatar
It was a Class A motorhome.
Old 06-18-2014, 12:40 PM   #7
Ford Idaho's Avatar
I saw two A class rigs with a jeep behind them one was a standard the other was a four door both looked just fine, no motion side to side that I saw and both were at or over 70 MPH when they passed me.
Old 06-18-2014, 12:52 PM   #8
BamaBob's Avatar
Sounds like something was SERIOUSLY wrong with their TOAD setup
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-18-2014, 12:52 PM   #9
Terier's Avatar
I didn't think it was normal and wouldn't want to be the driver either.
Based on my speed the MH in question was doing 65 mph. Here in SoCal the speed limit is 55 when towing. This area is a heavy traveled freeway especially with trucks. Even the semi trucks were moving out of the way.
Old 06-18-2014, 12:53 PM   #10
Campin Cajun's Avatar
I tow a Wrangler behind my coach. It has 35" tires with a 3" lift. No side to side. I have the rear view camera on it the whole time I am driving and I have never noticed any side to side motion.
Was the front of the motorhome going side to side also? Maybe the driver had a "few" too many.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 06-18-2014, 12:54 PM   #11
Terier's Avatar
Ditto. It reminded me of dog's tail wagging.
Old 06-18-2014, 01:06 PM   #12
Arefbee's Avatar
I was thinking that the longer motor-coach may have been obscuring the fact that the driver was trying to reach his iPhone on the floor.
(edit) Small control changes at the front can bring dramatic results to the rear because of the longer distance from rear the wheels to the hitch.
Old 06-18-2014, 01:24 PM   #13
Terier's Avatar
Reaching for something could explain some of the movement but the drifting went on regularly for the 8-10 miles I was traveling aside the MH.
Old 06-24-2014, 06:30 PM   #14
We tow a Jeep Liberty with our class C and I always have to check the rear camera to make sure it's still there because it tracks great.
tlf65 is offline   Reply With Quote
Old 06-24-2014, 06:42 PM   #15
VinceU's Avatar
A few years back I was towing a Wrangler with a standard A frame towbar. Enroute a pin fell out on the driver side attachment to the Jeep. It performed exactly as you describe like a dog's tail. Cars passed us and never said a word but as the damage worsened I could see the Jeeptrying to pass me, in the side mirrow! I pulled over and DW got into Jeep, Bar went into storage. Pretty scary as you said. It becomes a one point tow with the toad having steering, very bad.
Old 07-17-2014, 08:06 PM   #16
I have a friend that had his Wrangler try to pass him. He stopped and "had lost a pin". I gave him a hard time because you can't just lose a pin. You can forget to put the locking pin in it but they don't just disappear for no good reason. It got very wild before he got it stopped so as Vince said that could be the problem.
towing
