Old 02-13-2015, 06:48 PM   #11
HappyCamper77's Avatar
So I'm at home now and able to read exactly what the manual says. This is why I thought it had to do with the recover/bumper hitch difference....
" the rear bumper is intended to tow trailers up to a 5000lbs without added equipment or alterations to the standard equipment.
Ram 1500 4X4
Standard tow:5000lbs
Max tow:10350lbs
Max payload:1500lbs
I can't find any mention of WDH adding towing capacity. I will still look for the stamp on the recover like was mentioned.
Ontario, Canada
2014 Dodge Ram 1500 5.7
2015 Rockwood Ultralite 2905ss
Ontario, Canada
2014 Dodge Ram 1500 5.7L
HappyCamper77 is offline   Reply With Quote
Old 02-13-2015, 07:45 PM   #12
Factory receiver replaced
The 5000/500 lb. spec applies to the 4Runner with standard factory rear ladder mounted receiver. I installed a Draw-Tite frame rail mounted equalizer ready receiver and the spec on my 2005 4R goes to 6200/620 lbs. if using an weight equalizer hitch.
I am towing a 2109s with Equalizer 4 point hitch and have no problems. I always tow in "4" not "D" and keep the weight down in the TT (CAT says 4600 lbs. with no water/waste).
DRiveWell is offline   Reply With Quote
Old 02-13-2015, 08:37 PM   #13
Scubanut's Avatar
I ran a 2004 Four Runner V 6 towing forest rivers freedom Express 19ltz. Hauled it for two years, never had a problem. The dealer swapped out the factory hitch because of rust issues. They through the hitch into the deal.
Scubanut is offline   Reply With Quote
hitch, toyota, weight
