Old 07-10-2012, 07:47 AM   #31
Thanks everyone for the information! Is it true that short drives are bad for diesels, or is it an old wives tail? I only drive 6 miles to work and I read that you can end up with diluted oil. They were saying on shorts trips the engine won't get hot enough to burn off the fuel wash.
Len & Cheri is offline   Reply With Quote
Old 07-10-2012, 07:50 AM   #32
Its not that its bad, but diesels were meant to work under stress so if you buy one just to have it....then i would say yes but if you buy it and use it to tow then no. I drive about 15 miles to work in mine and never had a problem with either my current or my 07 DMax
2012 Ford F-350 6.7L CC SRW w/FX4
2013 Forest River Sierra 365SAQ
Beausdog is offline   Reply With Quote
Old 07-10-2012, 10:29 AM   #33
I have a similar commute (I work from home, but take the kids to school/daycare). The only problem is when the truck goes into regen (injects fuel after the combusion stroke to heat up the DEF and burn off the soot - read up on it) on your way home. It is bad to shut it off when it is in regen because it doesn't finish, then will go into regen the next time you drive, etc. It can get into an endless loop, and this is what dilutes the oil. If mine goes into regen on the way home, I will just take a little drive (10 mins out and 10 mins back) to let it finish. Mine regens about once per tank. I was really concerned about this before I bought my truck, but it has really turned out to be a non-issue. Since you are presumably buying it to tow, the occasional tow will allow it to work enough to "burn the cobwebs" out of it.
Again, you definitely want to follow the "severe service" intervals for oil changes just to be on the safe side. With a 6 mile commute, unless you do a lot of other driving, you'll be bumping up on the 6 month interval before the 5k mile interval.
2012 Flagstaff 8528 BHSS
2008 Ford F250 Crew Cab 4x4 6.4L Power Stroke
fordmantpw is offline   Reply With Quote
Old 07-10-2012, 11:46 AM   #34
It's sorta both, I want one to satisfy my wants and I could use it for towing . I'm real close on on 990 tongue weight (and sometimes over). I figured I could get a low mileage F250 and have $350 a month payments VS a new Ecoboost late next year and have payments of about $600. The savings is there if I do get an F250, plus I could actually carry some fresh water in my TT tanks.
The regen was another issue that bothers me. I could put up with it until the warrantry runs out and do a DPF delete with a small tune. That's supposed to really wake up the 6.4 and does away with the regen.
Decisions! Decisions!
Old 07-10-2012, 12:50 PM   #35
Listen to your father in law!
Wumba is offline   Reply With Quote
Old 07-10-2012, 01:02 PM   #36
You know, I've contemplated that as well. The thing that bothers me is that I get good fuel economy until regen kicks in, then it goes to heck! But, for the amount of fuel it takes to regen (.5 ish gallon / tank), it would take a long time to make back the cost of the DPF delete and tuner. But yes, I've heard from quite a few people that eliminating the DPF really wakes up the 6.4. I've got almost 3 years of warranty left on mine (I bought extended to 7 years, 60k for $1100 when I bought my truck), so it will be a while before (if) I find out.
Says the person with no argument to back up the statement...
Old 07-11-2012, 01:18 PM   #37
ironj's Avatar
My drive to work is about 8 miles one way....then on the weekend i will put 25-30 miles driving around....usually tow or haul something once a month....regens always seem to start when im pulling into driveway....lol..i just shut truck off and do my thing....
I am using a dpf/egr ON tune (all stock exhaust) and i only get one regen every 13days or so.
The truck will give you a wrning if the dpf needs to be cleaned.... instead of the quick 5 second message you will get the "DRIVE TO CLEAN' message constant...(tho i have never seen it in my truck')..
These new diesels are smart.....not like grandpas old tractor.....tho i do recommend for anyone considering one to do their part and research the whys and hows of these new complex exhaust systems mandated by the epa....
Normally i would just rip it out and run my truck 'old school natural'....but i for one appreciate and enjoy the quiet,and clean aspect of my new truck.....
Down the road if there are issues i will take it off and run a diff tune.....easy peasy...
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 07-14-2012, 06:50 PM   #38
TTNewbees's Avatar
Guys, thanks for the help and suggestions. Guess you answered my ???'s
Mike
2012 Lacrosse 303RK
2012 F250 6.7 diesel
TTNewbees is offline   Reply With Quote
Old 07-14-2012, 06:51 PM   #39
Nice!!!! She looks SEXY!!
Old 07-14-2012, 06:56 PM   #40
BOBFIDY's Avatar
Attachment 16505
Good looking truck.....Now just add it to your signature line.
We love our F350.
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
