Old 12-01-2015, 08:32 AM   #1
Bill Scott
Minimum turning radius
I have scheduled the installation of a back-up camera system for my 2015 Forest River Salem Hemisphere 337 BAR. The installer insist on me bringing the rig to their lot. Now, I am worried about being able to get the rig out of the lot after the installation.
The total length of the rig (including the tow vehicle), is approximately 60 feet. The lot is rectangular. The length of the lot seems long enough with room to spare, but I am concerned about the width. There is one way in, and the same way out, which means the rig must be turned around 180 degrees to exit the lot after the installation.
Obviously, this will require a number of forward and backward movements. The question is: Pulling the trailer with a 2014 GMC 3500HD dually, how wide must the lot be in order to make the u-turn?
BillScott is offline   Reply With Quote
Old 12-01-2015, 09:08 AM   #2
bubbles's Avatar
Why don't you back it in at delivery?
Old 12-01-2015, 09:29 AM   #3
turn adius
truck needs approx. 46 to 50.5 feet. do not know about trailer. but backing in or out would be the best thing to do.
2OLDDIGGERS is offline   Reply With Quote
Old 12-01-2015, 10:04 AM   #4
Bill Scott
The road to the parking lot is narrow with a building on the right and a fence on the left. Backing in or out would be difficult. The road is narrow and there are one or two curves to negotiate to get to the lot behind the building. I'm beginning to think it may be too risky to go there at all.
Old 12-01-2015, 10:14 AM   #5
Bill Scott
Also the road into the lot requires a 90 degree turn to the right. There is enough room to make the turn in.
Old 12-03-2015, 06:11 PM   #6
MacDR's Avatar
I would try a different installer.. If your out of your comfort zone bringing your unit to his business find someone else.
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
57 days Camping 2015
Winterized ..
2014 Columbus 340RK
Day's Camped 2018 "32"
You can find us: CrockeryCreek RV Park, MI 9/29 - 10/1
MacDR is offline   Reply With Quote
Old 12-03-2015, 06:20 PM   #7
Usually Confused Member
emm-dee's Avatar
Do a test run. Take the truck/trailer to a large, open parking lot (Wally world, Lowes, Home Depot after closing time) and set a cone or other marker next to the truck. Do a 180į turn as sharp as your comfort level allows, then measure the distance.
2018 Forester 3051S (aka Clyde)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 12-03-2015, 06:26 PM   #8
AquaMan's Avatar
You can make it. I had a GMC 3500 CC 4x4 and pulled a 42' 5er and was able to turn it around in the parking lot behind my shop. Lot is probably about 85' wide at best, but long. If you can turn the truck, you can turn a 5er! Just takes a little skill.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 38
Old 12-04-2015, 09:12 AM   #9
Bill Scott
Thanks you all, I found a reputable installer that has a pull-thru and the bonus is, he's a couple of hundred $$$ cheaper.
