Old 03-06-2016, 12:32 PM   #11
mike.t's Avatar
Been 2 5/16" for some time.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 03-06-2016, 12:50 PM   #12
Originally Posted by CNYCamper View Post
X2. My old 2008 Shamrock used a 2", but current is a 2-5/16" which is more common. Having trouble understanding why an employee of the dealership can't be troubled to walk out to the lot.
^^^Yep. This *might* be an indication of the level of service you could expect in the future. If the dealership can't convince someone (anyone) to walk by to verify, I don't think I'd trust them with ANY other issues that may arise....
Just my $0.02...
J.
jcrayford is offline   Reply With Quote
Old 03-06-2016, 01:11 PM   #13
Alex that is not correct. My vibe 6501 has a 2" receiver and it is not a popup.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 03-06-2016, 01:45 PM   #14
mike.t's Avatar
Just my $0.02...
J.
Ah yes tales of Camping World.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 03-06-2016, 01:47 PM   #15
mike.t's Avatar
Your lucky your trailer only weighs about 3000lbs. 2 5/16 is the standard.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 03-06-2016, 01:58 PM   #16
Why am I lucky? I was just pointing out that to assume that everything larger than a popup would have a larger ball could get someone in trouble. You should always see what the trailer hitch says.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Old 03-06-2016, 02:15 PM   #17
mike.t's Avatar
Cause you have a small trailer and the 2' ball is just fine. Trouble?
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 03-06-2016, 03:32 PM   #18
If you try too hook up your trailer with the wrong size ball it can lead to all kinds of trouble. Stuck ball or if too small the trailer could become unhitched. Just make sure you double check what the trailer hitch says because the dealer won't be there if something happens even if they said it was x size.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Old 03-06-2016, 03:38 PM   #19
mike.t's Avatar
Well put.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 03-06-2016, 11:38 PM   #20
Tom48's Avatar
Originally Posted by fonzie View Post
99.99% sure it is a 2 - 5/16 inch ball for that size of trailer......
X2 Runs in my mind that law, engineering or something set the ball at 2 5/16 any time the GVW gets above 6000 lb
Tom48 is offline   Reply With Quote
hitch
