Old 05-27-2016, 06:56 PM   #41
Sc00ter's Avatar
Originally Posted by northstar1960 View Post
what grade is this . the one heading into the south black canyon campground?
Yep. South side off st hwy 50 out of Montrose. Not sure if there was a campground but we were at the bottom of the canyon.
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is offline   Reply With Quote
Old 05-27-2016, 07:29 PM   #42
That is not the road to the campground. It is the road to the bottom of the canyon and no trailers are allowed according to the signs. There is a tent campground at the bottom.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-27-2016, 08:10 PM   #43
Sc00ter's Avatar
Yeah I do remember those signs. We were in first gear up and down and I remember the transmission went over 200 degrees after both trips. Not enough cooling air combined with an unlocked torque converter the whole way.
2015 puma 295bhss
Old 05-27-2016, 08:26 PM   #44
northstar1960's Avatar
The south portal .don't think there is camping for rigs down there .
northstar1960 is offline   Reply With Quote
Old 05-31-2016, 10:08 AM   #45
rvb
Originally Posted by RVBuzz View Post
My truck does not have a manual shift mode...shifter shows "PRND321" do i just have to slow down to the desired speed and then use cruise control to allow the truck to downshift from 4 to 3 and etc... or do I need to manually downshift to 3rd...
If so how can i do that while driving or do i have to come to a stop...shift from "D" to "3" and etc...
Thanks! Happy Memorial Day!
I have the same year F150. You can move from D to 3 no problem while driving. If you're going 60 in D in 6th and move it into 3rd, you'll jump from about 1800 rpm to about 3000 rpm iirc, depending on your gearing. I've used it even when not towing, eg when passing someone just to be in gear and more into the power band before I get the opening to go around. You can use it to climb or descend hills also.
If you have tow/haul enabled, the truck will pick a lower gear for you depending on slope, how much you're braking, etc. I would let it pick the gear vs putting into 3rd unless the tranny starts to "hunt" as conditions change then maybe you just want to lock it into a gear to help keep some heat out of the transmission...
you probably want to be going slower before you drop into 2nd or 1st, but I suspect the transmission electronics won't allow it to shift into the lower gears unless safe for the transmission to do so.
-rvb
Ryan V. B.
2017 FR Wildwood XLite 195BH
2010 F-150 4x4, 4.6L
rvb is offline   Reply With Quote
mount
