Old 02-21-2014, 08:25 PM   #1
Moving Brake Controller to Another TV
We currently tow our FR EVO 195BH with a 2010 Nissan Murano. This next trip i'm thinking about borrowing a 99 Ford Expedition (5.4l v8 and tow package) for the trip.
The only problem is, is that the Expedition does not have a brake controller. I was thinking about buying the ~$12 harness and moving the Prodigy P2 controller from the murano to the expedition. Will the murano drive fine without the controller plugged in?
I hope that makes sense.
Thanks,
Dan
danimal86 is offline   Reply With Quote
Old 02-21-2014, 08:31 PM   #2
buffalohunter's Avatar
There shouldn't be a problem at all. The Prodigy P2 controller is an add on.
2012 Rockwood Windjammer 3008 W
2007 Tundra Reg Cab 4X4 SR5 5.7L
buffalohunter is offline   Reply With Quote
Old 02-21-2014, 08:32 PM   #3
Ford Idaho's Avatar
Yes it will drive AND stop just fine.
All the Prodigy does is sent voltage to the mags on the trailer so the brakes will work.
Old 02-21-2014, 09:12 PM   #4
PPST OGCDG
Frank-VA's Avatar
I unplug my Prodigy Brake every year after camping season goes out. It takes less than a minute to remove it or to reinstall it. When you install it in the Expedition you need to check if it has the proper Relays installed in the Expedition.
1. FOAB-14B1192-A TRAILER TOW BATTERY CHG. RELAY
2. F57B-14B192-A TRAILER TOW BACKUP RELAY
3. F85B- 14A348 P260H HARNESS TO THE Expedition
All of the above should be kit that came with the Expedition located in the glove box:
The Harness kit XL34 15A416 AE // 374812
BE SURE TO CHECK THE OPERATING MANUAL FOR THE 99 Ford Expedition to make sure the numbers and parts are correct. The above numbers are from a 2001 F-150-F-250 EXPEDITION/NAVIGATOR INSTALLATION INSTRUCTIONS.
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
Old 02-21-2014, 10:32 PM   #5
bikendan's Avatar
how come you're thinking of towing with the Expy, instead of the Murano?
big difference between the two.
the controller has nothing to do with the Murano's brakes. it just senses you braking the Murano and sends a signal to the trailer's brakes to do the same.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 02-22-2014, 12:12 PM   #6
Thanks for the information everyone!
I want to try a different tow vehicle just to see how it does with the hills
Sent from my SM-N900P using Forest River Forums mobile app
Old 02-22-2014, 12:35 PM   #7
I've got a couple of questions as I have a very similar TT and I am always seeking other peoples expierence. Looking on Nissans web site, the max towing on the Murano is 3500 lbs. The TT your pulling I believe comes in at 3000 lbs dry. Do you have some kind of towing package installed or addition. I have a Trailblazer with a 5400 lbs towing capacity and I have really not pulled mine very far (just home from the dealership). Do you have any advice, other than borrow a Ford Expedition. Thanks
whitmw is offline   Reply With Quote
Old 02-22-2014, 12:57 PM   #8
Nothing additional on the murano. I was a bit nervous on our first trip, not knowing what to expect, but we picked somewhere close for our first trip. I see a truck in our future (that's why I'm borrowing the expedition). But if we were going to keep it for the long haul we'd add a tranny cooler. It's a small price to pay for piece of mind
Old 02-22-2014, 01:03 PM   #9
I have a single Prodigy P3 and I've got custom harnesses in both my Chevy Traverse and my Silverado. I can put the controller in either one at any time. No problem. The controller has NOTHING to do with the vehicles braking system. Only the trailers brakes.
2011 Traverse LT, 3.6L, FWD
Old 02-22-2014, 01:05 PM   #10
++ on the tranny cooler. I will be adding that soon. Thanks
brake control, controller, brakes
