Old 03-03-2015, 11:31 AM   #1
Mud flaps
Just bought a new Ford F 250 Lariat? What do some of you use as mud flaps to keep from throwing rocks and such up against your trailer? I have looked at several auto parts stores and cant find anything. If I can find it I would like a one piece that goes all the way across the back of my truck and if possible have it removable. Thanks
twosocks is offline   Reply With Quote
Old 03-03-2015, 11:42 AM   #2
When the weather warms and I get the truck from storage, think of installing these.
WeatherTech Molded No-Drill Mudflaps. WeatherTech No Drill MudFlaps Mud Flap for Chevy, Ford, Dodge, GMC, Cadillac | WeatherTech.com
Comments?
MartyQ is offline   Reply With Quote
Old 03-03-2015, 11:43 AM   #3
kenandterry's Avatar
twosocks........
This is your lucky day...........and they're on sale!!!!!!!!!!!
Mud Flap System - Rock Tamers 00108 - Splash Guards & Mudflaps - Camping World
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 03-03-2015, 10:44 PM   #4
twosocks
Here is a website that sells what you are looking for. They cost alot more than when I bought mine 3 years ago.
Cloud-Rider&reg Designs Ltd. - Product Features and Information
I'm not associated with them but pleased with my purchase and how well it works.
Good luck with your search.
Ken & Janet
'07.5 GMC 2500 D/A CC/SB
'09 SABRE 31RETS-6
wingriders is offline   Reply With Quote
Old 03-03-2015, 10:58 PM   #5
geotex1's Avatar
twosocks, why not consider the opposite and put a stone guard on the trailer? Treadbrite is inexpensive to DIY once you find you local metal supply. Spray on truck bedliner is a great alternative too and can be color-matched as well. There's also automotive paint protection film. I've used all 3 approaches between different campers and trailers I previously or currently own and they work well.
geotex1 is offline   Reply With Quote
Old 03-03-2015, 11:25 PM   #6
northstar1960's Avatar
Tow Tector . attaches to your receiver so easily removed when not needed
full width of your truck , it's the grass type
Towtector | Mudflaps.com
northstar1960 is offline   Reply With Quote
Old 03-04-2015, 06:23 AM   #7
Devilscreekw's Avatar
Bought the Rock Tamers a year ago when my trailer was new. I am 100% happy with them, though I did have to grind the gussets on my hitch shank a bit to make them fit between the hitch and the truck bumper. I also wrap tied a couple of pieces of foam plumbing insulation on the shafts of the Rock Tamer in case it jiggled loose and rubbed against the truck bumper.
You should check the adjustment bolts on the Rock Tamer each time you tow because they will back off, or dig into the shank and loosen up.
It does an awesome job of keeping rocks off the trailer, and as I am several miles off the pavement on a farm, keeping the trailer clean (which diamond plate alone will NOT do).
Harv & Deb
2015 Flagstaff 27RLWS
2010 Ram 2500 4x4 crew 5.7 Hemi, 3.73
Equalizer 1200 4 pt. Tekonsha controller
Devilscreekw is offline   Reply With Quote
Old 03-04-2015, 08:15 AM   #8
plshilo's Avatar
Comments?
Hey guy,
I have these and they work and look Great....only problem I had was had to drill out the rear holes to fit my own bolts.
Phil & Linda and our two four legged girls - Cricket & Lucy
2016 F350 Super Duty
2011 Prime Time 27.0 RET Crusader 5th Wheel
plshilo is offline   Reply With Quote
Old 03-04-2015, 08:26 AM   #9
Originally Posted by plshilo View Post
Hey guy,
I have similar factory installed Ram flaps, and they don't do nearly enough to prevent damage and mud from hitting the trailer. They do a good job in preventing damage to the truck, but I managed to through a rock clear through the aluminum skin of my old trailer.
Hence the Rock Tamers on my current TT.
Harv & Deb
Old 03-04-2015, 05:48 PM   #10
LANShark42's Avatar
Recently bought the Weathertech flaps for my new F250. The work and look great. VERY happy with them.
19xx Wife (named Melissa)
2014 Akita (named Mizuki)
2015 F250XLT 6.2l V8, 4x4, Supercrew, 3.73 Rear
10K WD Equal-i-zer Hitch
2015 Coachmen Catalina 273BH
LANShark42 is offline   Reply With Quote
