Old 09-19-2016, 07:30 PM   #21
Thanks for the info and encouragement about using tire monitors. I'm glad you made it thru this without major damage or injury. We have app. 7000 miles on the tires our 2015 Cruise Lite came with. I carry a Kobalt, 3 gal air compressor to add air if needed, as well as visual inspections and thumping them when we're stopped for fuel or food. So far, so good. This new monitor allows me to sleep without worry!
gfarmcafe is offline   Reply With Quote
Old 09-19-2016, 07:48 PM   #22
Maxxis Tires
There is a very good article on the Maxxis tires in the Sept issue of Trailer Life.
Sandy12345 is offline   Reply With Quote
Old 09-19-2016, 07:50 PM   #23
MarkyB's Avatar
It was mentioned that the tire was warmer than the others. What temperature difference would one start to get concerned?
16 F-250 Lariat 6.2 -- 16 Wildwood 31KQBTS
Nights Camped in 2016 : 25
MarkyB is offline   Reply With Quote
Old 09-19-2016, 07:59 PM   #24
CaptnJohn's Avatar
That was more of an extension to their 2 half page ads in the same issue. They are a good tire for sure but research sent me to Carlisle instead.
Old 09-19-2016, 08:04 PM   #25
Failure is my business
Hard to say. The tireminder temp alarms can be set to whatever you want, but generally I would say the temperature changes I would be looking for would be the result of a stuck brake rather than the subtle drag caused by my failing tire carcass. (Additionally the Tireminder accuracy is +-3F or so, (I think) so it's not really scientific quality instrumentation.) The actual temps I was seeing were about 93-95 F on three of the tires and 103F on the bad one after 80 miles of 65mph towing in 90F ambient. It was pretty subtle.
The way I look at it now, the temps I saw by themselves would not worry me tomorrow. However, add to that a newly noticed vibration, and I'm at least pulling over and thumping the tires to see if anything sounds funny.
Current vehicle list: 16 Flagstaff 832IKBS, 14 RAM 1500 4x4 Hemi 3.92 Bilsteins!, 04 Dodge Ram SRT-10 40,000 miles, 97 F150 4x4 5.4L 243,000 miles, 80 Firebird Esprit Aussie Burnout Car https://youtu.be/v06VjII7HmE, 78 Harley Davidson FX 79,000 miles dad bought new, 71 El Camino ZZ3 TH400 12-Bolt, 37 Ford 3 window 502 Chevy dad built
2Evil4U is online now   Reply With Quote
Old 09-20-2016, 05:06 AM   #26
Originally Posted by 2Evil4U View Post
Posts 2, and 6.
Oops, I totally spaced it. Thanks for pointing that out. I guess I was looking for his analysis and/or confirmation of the OP's thoughts on the failure.
David and Vicki
6 year old Springer rescues Sydney and Piper
2014 GMC Denali 3500HD Dually Crew Cab Duramax/Allison stock "Doug"
2016 Dutchmen Denali 287RE "The Dog House"
Eaz Lift WDH 1400# w/ Blue Ox 2 1/2" trunion
EezRV TPMS
Springerdad is offline   Reply With Quote
Old 09-20-2016, 10:06 AM   #27
VaJim
tire failure
Just a thought, you might want to check that wheel to see if you have a brake to tight causing the tire to get warmer than others and causing the tread to separate. I replaced all my tires with E rated Hercules made in the USA
2010 Ram 1500 Quad 4X4 5.7L
2012 V-LITE 30WFKSS
VaJim is offline   Reply With Quote
