Originally Posted by SeaDog
OK I understand now, the reason is the hitch is transferring weight to the TV which is as it should be. maybe I'm still missing something but this would seem normal to me.
So without the WDH , I tx 980 # from tongue to TV....that is normal to me also, but where I get really confused is when the WDH is engaged the TV weights less....\
the 980 lbs is reduced by 140 lbs....so if I take the numbers at face value and and coupled with the wheel measurements, this is what is happening:
the tongue wt is being reduced by 140 lbs (shifted to the TT Axles) and what is left on the rear axles of the TV is shifted to the front TV axles....
And if that is correct, the tongue wt is now only 840 lbs....is this the tongue wt value to use in the 10-15% target or should I use the 980....
I am confuse on how much wt in the front of the TT to shift aft in the TT....
