Old 06-19-2017, 06:41 AM   #21
Dave Lyon's Avatar
My 2009 GMC 1500 looked similar. I think it's just normal wear. I didn't worry about it.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 06-19-2017, 07:04 AM   #22
Originally Posted by SidecarFlip View Post
the holes are punched not drilled and they are punched before the material is roll formed (it's flat) so the alignment when punching was off. It's not profitable to drill that many holes. Hitches are made on a production line with robotic equipment. A lot of OEM receiver hitches) are manufactured in Findlay, Ohio btw.
Me thinks the holes are punched in the tubing that is already made.
Old 06-19-2017, 09:03 AM   #23
My 07 2500 GMC Sierra same thing. Have 10K toy hauler, didn't lub the ball which elongated the pin hole. Bought a new Curt brand heavier hitch. Haven't put it on yet.
larry.mahoney is offline   Reply With Quote
Old 06-19-2017, 10:24 AM   #24
OP.....don't worry.....its from "work/towing". Yours is a mild case....should see my workhorse GMC Sierra. It's a 2011 with 60K miles. 45K pulling miles.
cornhusker is offline   Reply With Quote
Old 06-20-2017, 12:13 AM   #25
Rhody's Avatar
Originally Posted by EdnKat View Post
Use a little CRC White Lithium Spray Lube. Helps stop the wear from dust grinding.
I would give that a good wire brushing an wire wheel an a nice coat of rustolium black paint...maybe a primer first...
Do the pin too!
Sent from my SCH-I605 using Forest River Forums mobile app
Rhody is offline   Reply With Quote
Old 06-20-2017, 12:50 AM   #26
Just a member
kandl's Avatar
Originally Posted by lugoismad View Post
Is this normal wear and tear? or should I be concerned? This is an OEM hitch on a 2013 Silverado.
Yep... crappy steel.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
kandl is offline   Reply With Quote
Old 06-20-2017, 05:58 AM   #27
RabbitFamily's Avatar
I have the anti-rattle, and a Master Lock pin that slides tight. My hitch doesn't budge. Amazon. Got both for around $50 +/-. Also, be sure to grease everything
RabbitFamily is offline   Reply With Quote
Old 06-20-2017, 06:15 AM   #28
Rhody's Avatar
Chinese Steel...
Old 06-21-2017, 10:10 AM   #29
Old 06-21-2017, 10:38 AM   #30
waiter21's Avatar
My hitch stays in the receiver so I installed a anti rattle device to prevent the hitch from wobbling around in the receiver and beating the hell out of the pin.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 06-21-2017, 10:45 AM   #31
Rhody's Avatar
Rustolium and a new pin!
Old 06-21-2017, 04:55 PM   #32
What anti rattle device is everyone using? Brand, Company and where you bought it?
XLR 24 HFS
Bpenn is offline   Reply With Quote
hitch, light
