Old 07-20-2012, 08:30 PM   #11
cstover's Avatar
Oh and my brackets sit below my propane cover.
cstover is offline   Reply With Quote
Old 07-20-2012, 08:32 PM   #12
Twisty's Avatar
I moved the propane tanks forward and slid the brackets as far forward as they would go. Now they are against a frame bracket and my chains are not perfectly vertical. The tank cover rests on top of them.
I am not going to cut the piece out and have it moved 1/2"!
The frame designers fell on their collective faces.
Oh Well...
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 07-20-2012, 08:40 PM   #13
cstover's Avatar
Just do the best you can. Other than that have fun.
Old 07-20-2012, 08:49 PM   #14
I would move the brackets forward until the chains were vertical and notch the cover or just take it off until hooked or lift it a little until hooked. Not a major operation.
Old 07-20-2012, 08:54 PM   #15
cstover's Avatar
He is now hitting a cross brace.
Old 07-21-2012, 07:00 AM   #16
Leathergypsy's Avatar
Is it possible that maybe the ball is too low? from the pics, it looks like the camper is angled downward.
John N.
Madison Heights, Mi.
2009 Salem LE 27RBEC
2013 F250 Lariat 6.2L
Leathergypsy is offline   Reply With Quote
Old 07-21-2012, 08:35 AM   #17
Me being me, I would be doing some re-arranging on the tongue. The chains should hang straight down to be the most effective. Batteries & propane tanks can be moved around to facilitate the proper placement of the over center latches.
Old 07-29-2012, 11:03 AM   #18
RollingDownTheHighway's Avatar
re
Today I spent some time making some adjustments. I moved the chain brackets up so they're straight up and down and even on both sides. (they weren't from the dealer), I did a test run and made some changes with how many links to leave remaining.
suggestions, comments are greatly appreciated:
I went to my test site with 4 links loose, made a change and only went had 1 link loose on the ride back. I tried to do my measurements but I can't find a flat surface to save my life where I live.
ID:	17217   Click image for larger version
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 07-29-2012, 11:10 AM   #19
Can you find a parking lot somewhere that isn't busy or crowded and just play with it there?
Old 07-29-2012, 11:12 AM   #20
i found several, however non are flat so I can't get good measurements to compare with my start. I did starting measurements in my garage.
