Old 07-04-2013, 08:22 PM   #41
Itsthetwoofus's Avatar
Smile
Originally Posted by Mr.z View Post
Had an F-150 with the same set-up. To many problems with the EcoBoost in the hot humid weather. Sold it,
and got F250 Turbo diesel 400HP, 800 Ft lbs of torque. This thing will pull a house.
You got that right.. It does pull my house.
2011 Cedar Creek 36B2 ordered with outside kitchen removed and a nice big wardrobe in it's place.
Pulled with a 2011 F-250 Super Duty 6.7 Diesel Crew Cab and 8' box with a Hensley BD-3 Trailer Saver. F R O G members.
<a href=http://www.forestriverforums.com/attachments/signaturepics/sigpic9630_4.gif target=_blank>http://www.forestriverforums.com/att...gpic9630_4.gif</a>
Itsthetwoofus is offline   Reply With Quote
Old 07-04-2013, 08:33 PM   #42
Originally Posted by bakken View Post
That might be the case if the camper hitch was directly over the rear axle, which it obviously is not.
To get the tongue weight, simply subtract the gross weight of the truck and the camper axle weight from the total gross weight.
12,620-6320-5520=780 pounds
Simple if you just stop and think about it for a second. Numbers can be confusing, and this weight balancing business especially so.
Or 40 pounds more if you use the second total gross weight of 12,660
not sure why they would be different, but 40 pounds isn't a bunch.
I was referring to the hitch tongue wt. I guess I should have been more specific. To get the actual tongue weight at home, get a 4 x 4 and a set of bathroom scales.
To use the method in the Figure, follow these guidelines:
Zero the scale with the board on the scale
Always place the trailer tongue 1 foot from the pipe on the support brick
Multiply the reading on the scale by the total distance between the 2 support pipes
Use a brick that is the same thickness as the scale so that the 2 x 4 is level when you weigh your trailer
For example, if the distance between the trailer tongue and the pipe on the scale is 2 feet and the distance between the trailer tongue and the pipe on the support brick is 1 foot, then you would multiply the reading on the scale by 3 to get the tongue weight. If the distance between the trailer tongue and the pipe on the scale is 3 feet and the distance between the trailer tongue and the pipe on the support brick is 1 foot, then you would multiply the reading on the scale by 4 to get the tongue weight.
Old 07-04-2013, 08:45 PM   #43
Dave_Monica's Avatar
Omega Quest already said that he measured tongue weight at 800 - 850 lb.
The 1100 lbs weight increase on the rear axle is because the tongue weight is loaded about 4' behind the axle centerline, reliefs 320 lbs off the front axle which makes the tongue weight 780 lbs.
Dave
Old 07-04-2013, 08:49 PM   #44
Originally Posted by Dave_Monica View Post
Omega Quest already said that he measured tongue weight at 800 - 850 lb...
Missed that!
Old 07-04-2013, 08:49 PM   #45
Dave
Simple math, but can still be confusing when juggling a bunch of numbers.
But if the OP's truck and camper sit fairly level, I would say he is good to go.
While getting all of the weight back on the front wheels would be nice, it may be impractical.
bakken is offline   Reply With Quote
Old 07-04-2013, 08:53 PM   #46
...While getting all of the weight back on the front wheels would be nice, it may be impractical.
Takes a little tinkering to fine tune it, but it is possible.
Old 07-04-2013, 08:56 PM   #47
Without the WDH bars activated, the "hitch tongue wt" and the actual tongue weight are the same, 780 lbs, or 820 if you use the higher total gross combined weight.
Old 07-04-2013, 09:23 PM   #48
another_newfie's Avatar
Nice lookin' truck. Unfortunately with all the bling it's tow ratings are terrible. Built to look pretty (which it does in spades), not to haul.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 07-04-2013, 10:54 PM   #49
FYI, I used a Sherline Trailer Tongue Weight Scale (2,000 lbs. gauge) under the jack to get the 800-850 lbs number.
OmegaQuest is offline   Reply With Quote
Old 07-05-2013, 08:35 AM   #50
Numbers look good to me.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
