07-04-2013, 08:22 PM
#41
Originally Posted by Mr.z
Had an F-150 with the same set-up. To many problems with the EcoBoost in the hot humid weather. Sold it,
and got F250 Turbo diesel 400HP, 800 Ft lbs of torque. This thing will pull a house.
You got that right.. It does pull my house.
2011 Cedar Creek 36B2 ordered with outside kitchen removed and a nice big wardrobe in it's place.
Pulled with a 2011 F-250 Super Duty 6.7 Diesel Crew Cab and 8' box with a Hensley BD-3 Trailer Saver. F R O G members.
07-04-2013, 08:33 PM
#42
Originally Posted by bakken
That might be the case if the camper hitch was directly over the rear axle, which it obviously is not.
To get the tongue weight, simply subtract the gross weight of the truck and the camper axle weight from the total gross weight.
12,620-6320-5520=780 pounds
Simple if you just stop and think about it for a second. Numbers can be confusing, and this weight balancing business especially so.
Or 40 pounds more if you use the second total gross weight of 12,660
not sure why they would be different, but 40 pounds isn't a bunch.
I was referring to the hitch tongue wt. I guess I should have been more specific. To get the actual tongue weight at home, get a 4 x 4 and a set of bathroom scales.
To use the method in the Figure, follow these guidelines:
Zero the scale with the board on the scale
Always place the trailer tongue 1 foot from the pipe on the support brick
Multiply the reading on the scale by the total distance between the 2 support pipes
Use a brick that is the same thickness as the scale so that the 2 x 4 is level when you weigh your trailer
For example, if the distance between the trailer tongue and the pipe on the scale is 2 feet and the distance between the trailer tongue and the pipe on the support brick is 1 foot, then you would multiply the reading on the scale by 3 to get the tongue weight. If the distance between the trailer tongue and the pipe on the scale is 3 feet and the distance between the trailer tongue and the pipe on the support brick is 1 foot, then you would multiply the reading on the scale by 4 to get the tongue weight.
07-04-2013, 08:45 PM
#43
Omega Quest already said that he measured tongue weight at 800 - 850 lb.
The 1100 lbs weight increase on the rear axle is because the tongue weight is loaded about 4' behind the axle centerline, reliefs 320 lbs off the front axle which makes the tongue weight 780 lbs.
Dave
07-04-2013, 08:49 PM
#44
Originally Posted by Dave_Monica
Omega Quest already said that he measured tongue weight at 800 - 850 lb...
Missed that!
#45
Dave
Simple math, but can still be confusing when juggling a bunch of numbers.
But if the OP's truck and camper sit fairly level, I would say he is good to go.
While getting all of the weight back on the front wheels would be nice, it may be impractical.
07-04-2013, 08:53 PM
#46
...While getting all of the weight back on the front wheels would be nice, it may be impractical.
Takes a little tinkering to fine tune it, but it is possible.
07-04-2013, 08:56 PM
#47
Without the WDH bars activated, the "hitch tongue wt" and the actual tongue weight are the same, 780 lbs, or 820 if you use the higher total gross combined weight.
07-04-2013, 09:23 PM
#48
Nice lookin' truck. Unfortunately with all the bling it's tow ratings are terrible. Built to look pretty (which it does in spades), not to haul.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
07-04-2013, 10:54 PM
#49
FYI, I used a Sherline Trailer Tongue Weight Scale (2,000 lbs. gauge) under the jack to get the 800-850 lbs number.
07-05-2013, 08:35 AM
#50
Numbers look good to me.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
07-07-2013, 06:01 PM
#51
Ford makes the absolute best looking (and probably best built) truck around and yours is a perfect example of this. Love the dash setup and the informational panels you have.
2021 Micro Lite 25FKBS
2021 Ford F-250 XLT CCSB 4wd w/ 6.2l and 6 sp. transmission, 3.73 locking axle
07-09-2013, 12:29 AM
#52
While I do agree that Ford's setup is attractive, I wouldn't say best by any means. It's subjective at best. In my case, I was going to go with a 6.2 Platinum Limited (or whatever the model was that only had 2500 built/serialized) but Ram flat out earned my business.
That brings back the memory of the Ford salesman telling me I should be considering the EcoBoost. After having a 6 cylinder Ranger, I thought he was blowing smoke.
Anyway...I'm learning an awful lot from you guys about the numbers and their interpretation.
V-Dub
2009 Jaguar XF Premium
2011 Kawasaki ZX10-R - Akrapovic EVO, BMC, ECU reflash, SS Brakelines, & Blockoff plates
2011 Ram 1500 Laramie - Crew, Rambox
2012 Harley Davidson Street Glide CVO - V&H HO's & PC-V
07-09-2013, 04:33 AM
#53
You have to know what the max payload is based on, springs, axle brgs, frame etc to determine whether you can increase it. To my knowledge, only the mfg knows what it is based on. If it were based on springs, then airbags would increase it. If it is axle brgs, you would not be able to increase it.
THIS... I've been on other forums and heard all the same arguments about payload. In my opinion since the frame is involved and also the GVWR, you really can't increase your payload number. You can just make trucks tow better with a load on them. Remember, unless you can convince a lawyer of this, then it's not official.
V-Dub
I'm not a blind believer for ecoboost by any means. I'm an eternal skeptic about a 3.7L V6 with (in some cases) 10K+ of towing capacity. But It's not that much of a stretch any more. The same engine series in many trucks with revisions to valve setups and compression ratios are putting out 50-100 more HP or at least close to it that the same block designs from 10 years ago. I commend Ford for thinking outside the box and giving drivers a reasonable fuel economy for their daily driver and power when needed for their toys.
Someone here said the OP could've gotten a 6.7L 250 for about the same price. But it's sounds like Omega thought about it, bought a premium trim level and balanced that with a lower cost of ownership. Smart move in my opinion.
2008 F150 FX4 5.4L & 3.73s
2014 PTM Tracer 3200BHT
Yes...I've finally made it to Prime Time!
07-09-2013, 02:59 PM
#54
Ok, I'm gonna try uploading a pic of the TV and TT.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
07-09-2013, 03:09 PM
#55
Patiently waiting
07-09-2013, 03:12 PM
#56
I guess my iPad isn't gonna let me in the usual way. I'm gonna try something. Stby
Duramax/Allison
07-09-2013, 03:13 PM
#57
Yep sittin on pins an needles here.
07-09-2013, 03:18 PM
#58
I'm gonna see if I can send myself an email, with the pic, then post it. Take a pill! I'm tryin'!
Duramax/Allison
