Old 02-04-2014, 12:07 PM   #1
CCRVOC
Ramblin Recks's Avatar
My Ram 3500 Recall is confirmed
Just called the dealer, and he told me what to look for to verify that I need the replacement. From under the front of truck, look just to the passenger side of center of the tie rod and if the stabilizer shock is mounted to the tie rod with two muffler type clamps you could have a problem . A new tie rod and front end alignment is in my immediate future.
Oh, recall is for the left tie rod ball stud may fracture under certain conditions... causing problems.... 2008-2012, Ram 1500/2500/3500 pu.
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 640w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
Old 02-04-2014, 12:14 PM   #2
DW works in an engineering firm that does accident reconstruction for attorneys. Nearly 70% of their cases are Dodge/RAM/Chrysler, and almost 80% are ball joint failures on 2500+ series trucks. Keep an eye on those things, or consider an upgrade!
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
Old 02-04-2014, 01:23 PM   #3
Fulltime family RVer
I got my recall paper a couple of weeks ago. Need to get into the dealer to take care of it.
Old 02-04-2014, 03:13 PM   #4
TURBS's Avatar
Fyi and may not be the case but the last time I had warranty work done on a dodge on the the front suspension a "required" alignment wasn't covered , just the repair.
TURBS
oc's buddy
Old 02-04-2014, 03:36 PM   #5
CCRVOC
TURBS
oc's buddy
I questioned that and dealer said front end alignment was covered under the recall, no problem.
3500, 500, recall
