Old 12-29-2015, 05:11 PM   #21
Total Loss's Avatar
Originally Posted by Ken K. View Post
Just had to take a sawsall to the jounce stop. I also had to drill some 5/16" holes for the fill valves. Other wise it was a straight forward bolt on set.
Here's the to a video of an installation on a similar truck.
Did they tell you to cut the bump stop?
Don't want to bottom out the air bag or the shock when you are running no or low air.
No good for the air bags if they bottom...or the shock if it reaches it's down travel limit.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 12-29-2015, 07:57 PM   #22
Ambassador
Ken K.'s Avatar
Minimum air pressure of 10 PSI, yes you do cut the jounce stop of flat with the shackle u bolts.
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
Ken K. is offline   Reply With Quote
Old 12-29-2015, 08:19 PM   #23
Ambassador
Ken K.'s Avatar
Tyger makes bolt on mirrors for all trucks I think. Here's the Search link for Amazon, just enter your truck make model to filter for your vehicle, if you're interested.
Amazon.com: tyger mirrors: Automotive
Old 12-30-2015, 10:48 AM   #24
Joust Bumpers
TotalLoss, with the Siverado and Sierra, the joust bumpers are totally removed and the Ride-Rites attach to the frame at that point. As long as minimum pressure is maintained in the bags there is no problem. Apparently this varies per vehicle manufacturer.
PenJoe is offline   Reply With Quote
Old 12-30-2015, 11:01 PM   #25
They have joust bumpers built inside the bags now so pressure really isn't an issue
jerky is offline   Reply With Quote
towing, modifications
