12-25-2015, 04:28 PM
Ambassador
My towing mods that I just made to my Little Tacoma.
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
12-26-2015, 05:28 PM
I like the mirrors!!
2006 Honda Goldwing
2012 Toyota Tundra DC s(sold)
2015 Cherokee Grey wolf 19RR Limited
2017 F150 Super Crew 3.5eb 5.5
12-26-2015, 05:53 PM
Nice Towing Mod's! Can you lower the Tailgate while hooked up? Youroo!!
12-26-2015, 06:39 PM
Originally Posted by Ken K.
I bought my Tacoma back in March 2015. I bought my 2015 Rockwood 2502KS Mini Lite shortly there after. So I took a weekend and Installed a couple of upgrades just to make the trips a little nicer. First up I installed some Firestone Ride Right Air Bags. These were bolt on, really glad I didn't have to drill holes in my frame.
i have a nissan titan cc. I've got a guy in my area that took some firestone air levelers he took off of his titan, for RV towing, and wants to sell them pretty cheap. the mounts look very similar to yours. if you don't mind revealing some facts, what prep did you perform to install on the truck?
thanks in advance.....
the faulks & prince
2012 Nissan Titan CC
Roadmaster Active Suspension, Firestone Airbags
2015 Rockwood 8289WS Diamond Pkg
2015 Puma 253FBS (sold)
2013 BMW R1200GSW
12-27-2015, 01:32 PM
Air bag install
Hi I've installed airbags on my Tundra and my buddies, Dodge and Tundra. Install is straightforward. Usually need to cutoff rubber jounce that keeps leaf springs from hitting frame of truck. Everything else is simply Bolton with no other prep other than jacking truck up and removing tire for better access to install. Run air lines to an area where you can easily access to fill or empty bags. If you visit Firestone site you can view copy of installation instructions.
12-27-2015, 01:51 PM
Interesting mods. I'm going to check them out for my '08 Taco.
Me, Wifey, Thing 1 & 2 plus Gracie the Shitzu rescue
FR Shamrock 233S 2015
2018 Ram 1500 Hemi 5.7 4x4 3.92
Nights Camped: NOT NEARLY ENOUGH!
12-27-2015, 02:17 PM
Tm,
Here's a pic of fire stones on 2006 Nissan crew.
The Tacoma mods, very nice, air bags are awesome.
12-27-2015, 02:29 PM
I see you have leaf springs what not just go to a truck spring shop and have them add a leaf or two to each side ?
12-27-2015, 02:36 PM
Air bags allow the option of leveling while still maintaining stock ride. Simply run 5 psi for stock and go up to 70 psi plus, if say towing, or heavy payload, common sense needs to be factored in as air bags or springs do only level the load not make things safe. Also air bags can be done by DIY for $225.00. Takes 2 hrs to install and if you wanted to removal when you sell truck?
These were the reasons I went bags.
12-27-2015, 03:29 PM
that is great info.
didn't think about their website....:roll eyes:
thanks...
the faulks & prince
2013 BMW R1200GSW
12-27-2015, 03:30 PM
tnfaulksr, go to the Firestone Ride-Rite website
http://riderite.com/Ride-Rite%20Product%20Detail
Do a "vehicle search" to make sure they fit model to model. Check the chart for your year and model and then of the sellers vehicle and model. The part (kit) numbers will probably be the same. If they are, these are pretty easy to install. Just make sure the bags were not damaged on removal and that you have all of the parts. As john5646 states, a new kit is $225. A bag replacement is about $100. They are well worth the $225-cheap is better if they are in good shape.
I believe that you can get the mounting instruction from Ride-Rite for your TV as-well. Mounting varies slightly from vehicle to vehicle, but no drilling of holes is required.
I removed a set of Ride-Rites from an '08 Sierra and wanted to put the on a 2013 Silverado. Basically the same bodies. However, the part numbers did not match, so I ordered a set for the Silverado. When the new ones arrived, I compared them with those from the Sierra. The only difference was that the top mounting hole was oval on the new ones and round on the older set. The new set would fit the '08 Sierra and the '13 Silverado, but the older set hole would have to be made oval and the would have fit. Had I known that, I could have saved some money and just reamed the holes oval by a quarter inch.
12-27-2015, 03:31 PM
good stuff....
the faulks & prince
2013 BMW R1200GSW
12-27-2015, 03:34 PM
appreciate it... good info & thanks for the website.
we both have titan cc
his an '08 mine a '12
website shows that '04-'15 Titans are all the same...
he wants $150 for the firestones & a 5th wheel pin-tripod support.
the faulks & prince
2013 BMW R1200GSW
12-27-2015, 04:08 PM
are those stock shocks??
they look like bilsteins or something like that....
the faulks & prince
2013 BMW R1200GSW
12-27-2015, 04:13 PM
Rancho shocks
12-27-2015, 04:16 PM
Rancho shocks
ok great checked out their site...
thanks
the faulks & prince
2013 BMW R1200GSW
12-27-2015, 05:21 PM
Since you are all talking about mods for towing, just bought an AFE exhaust from Amazon for daughters boyfriend for his new to him 14 taco. Was 395. Not huge power gain but sounds nice.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
12-29-2015, 10:52 AM
Ambassador
Just had to take a sawsall to the jounce stop. I also had to drill some 5/16" holes for the fill valves. Other wise it was a straight forward bolt on set.
Here's the to a video of an installation on a similar truck.
12-29-2015, 01:16 PM
Ambassador
lol No!
12-29-2015, 01:19 PM
Ambassador
I didn't want to have a stiff ride all the time. The air bags allow me to stiffen the suspension when I need it, and then go back to the soft stock ride when I'm not towing.
