Old 07-23-2019, 12:01 PM   #1
my weigt ticket whats good?
3480 steer axle
4400 rear
trailer axle 7780
total 15660
trailer is 35'11 f
river 294bh
Bryan294bh is offline   Reply With Quote
Old 07-23-2019, 12:30 PM   #2
Fulltime family RVer
That's not enough information to tell you anything. For a travel trailer, you need to do 3 weights:
1) Truck + trailer with WDH engaged
2) Truck + trailer w/ just coupler on ball (throw the WDH bars into the truck bed)
3) Truck only
Here's an article on it:
https://learntorv.com/how-to-weigh-a-travel-trailer/
And once you have the 3 weigh slips, here is a calculator you can use:
Actual Weights - Travel Trailer/Bumper Pull Weights from CAT Scales - Towing Planner
Old 07-23-2019, 08:38 PM   #3
If you have a 1/2 ton pickup you are probably over your GVWR and RAWR.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 07-23-2019, 08:52 PM   #4
Coach
Have you compared those numbers to those on the door of your truck and axle rating for the trailer? As was stated, really not a lot of info to go on.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is online now   Reply With Quote
Old 07-23-2019, 09:04 PM   #5
OP's profile shows he is towing with a 2017 Nissan Titan.
Front & rear axle weights total 7880.
Specs:
Payload And Towing
Payload
1329-1941 lbs
Max GVWR
7100-7300 lbs
Max trailer weight
9230-9390 lbs
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 07-24-2019, 04:52 PM   #6
9230 is the rating to be towed.. at 7780 on scale.. have weight it without bars on and truck alone
