Greetings, I’m new here and have learned a lot already. Have had our Avenger 21TH for a year now. Last winter was our first long trip. From Michigan to Texas and back. I made a rookie error and assumed the dealer set my Equalizer hitch up correctly. Not so, I had more sway than I thought I should. Upon further inspection, all the bolts were tight but none of them were torqued to the proper spec. The sockets for the spring arms are supposed to be greased and torqued to 60 ft lbs. mine had little grease and were tightened to about 30 ft lbs. After greasing and tightening everything on the hitch to the proper specs, the trailer handles WAY better! The moral of the story is (and one thing I’ve learned from this site) don’t trust the dealer, check everything. Also, whoever posted that when you buy an RV you are buying a “kit” that is 80% complete and it is up to you to complete the other 20% is absolutely correct!
John
