Old 06-04-2010, 10:53 PM   #21
Originally Posted by blake2727 View Post
The tanks I am talking about are DOT approved and are made of steel and stretch from one side of the bed to the other. They are made specifically for this purpose.
Do you have some kind of strap system to mount these? I'm sure some states laws would be against just having a loose tank floating around in the bed. I realize it will stay put when there is fuel in it, but what about empty or during a crash. Just thought of another thing- are they gravity fed or do they use their own pump? Would think some states would require some type of fuel shut off, too.
MightyMike is offline   Reply With Quote
Old 06-10-2010, 06:54 AM   #22
Sorry about being so late on a reply. The tank bolts down to the bed at all four corners of the tank. They do have there on pump and it turns on and off automatically. It has a little computer that mounts inside the truck and tells you how many gallons are in the in bed tank, the stock tank, and how much is in both tanks combined. It also tells you when the pump is on or off.
blake2727 is offline   Reply With Quote
Old 06-10-2010, 08:02 AM   #23
I installed a tank from ATTA. Look in this thread for mine.
aintgotnun is offline   Reply With Quote
