Old 03-21-2019, 09:53 PM   #1
Need a truck for a 5th wheel
We are making the jump from a TT to a 5th wheel and need to purchase a good used truck. I'm figuring a 3/4 ton with a crew/extended cab, and probably gas instead of diesel due to cost. Should I look for 4x4 or is 2WD sufficient. I have no allegiance to any brand but my son is a GMC man and my brother is a died in the wool FORD man. I've owned a Dodge Durango w/5.7 Hemi and had great luck with it...but it was an SUV and not a truck. I also know this is as divisive as talking politics, but I need your inputs and suggestions.
kermitvb is offline   Reply With Quote
Old 03-21-2019, 11:04 PM   #2
All of the big 3 manufacturers make a good 3/4 to 1 ton gas truck. Pick the one you like best and find the best deal on. They’ll all work.
Tatsngats is offline   Reply With Quote
Old 03-21-2019, 11:27 PM   #3
Fulltime family RVer
What size fifth wheels are you considering?
ependydad is online now   Reply With Quote
Old 03-22-2019, 07:37 AM   #4
nc-canuck's Avatar
Trailer weight is the key driver of what truck can safely work. Links below are to the Ford towing online resources.
1st link is to the towing guide for each year
https://www.fleet.ford.com/towing-guides/
2nd link is the 2019 towing guide.
https://www.fleet.ford.com/resources...e_r4_Jan29.pdf
As you can see from page 23 F250 SRW (single rear wheel) capabilities go from 12.2k pounds to over 18k pounds dependent on engine and axle ratio. DRW (Dual Rear wheel) can pull over 30k pounds.
2x4 or 4x4 will work but through the years I have found I prefer a 4x4 just in case.
2016 Rockwood Windjammer 3029W
2013 F350 Lariat Longbed 6.2L
nc-canuck is online now   Reply With Quote
Old 03-22-2019, 08:17 AM   #5
About 31 ft and 8000 lbs
Old 03-22-2019, 08:24 AM   #6
Hey people on here will mostly tell you to buy a dually 450 or a 550. If it was me I would probably buy a one ton truck SRW. The cost will be about the same as a 3/4 ton truck. Myself I never want a dually.
spock123 is offline   Reply With Quote
Old 03-22-2019, 08:29 AM   #7
If you are buying used, see if you can find one with Remaining warranty, that may help sway your decison one way or the other. All 3 teams, have great gas 3/4 tonnn and 1 ton trucks now days. The GM 6.0 comes factory with 4:10 gears I believe, where the ford and Ram have a 3:73 option. The Ram with the 6.4 pulls very well, but suffers from a large gap between first and second that sometimes makes accelerating up steeeper hills from a stop annoying, but with only 8K, it shouldnt be an issue. the 6l.4 is a wonderful motor. The 6.2 in the FOrd got updated in 2017 for Slightly More HP and TQ.. You really cant go wrong towing an 8K trailer, and since you arent buying new, the new Ford and GM gas Engines wont be part of the consideration, nor will the new 8 speed tranny with the Ram. All 3 will have the 6 speed autos, and are pretty stout and can take decent abuse.
If you were over 10K pounds on your RV, then I would have a favorite, but staying around 8K, its all good.. and BTW, im anxious to know what 5th wheel you are getting that weights 8K pounds, cause if thats dry weight, you may as well figure you will be closing in on 9.5K all loaded up.
Ron and Kathy
2018 Cherokee Limited 304 BH.
Towed with a 2018 RAM 6.7 3500 G56
ronheater70 is offline   Reply With Quote
Old 03-22-2019, 08:47 AM   #8
Jim34RL's Avatar
X2; I agree totally with spock123.
I would also make the truck a diesel engine vehicle and do not worry about the artificial payload numbers that everyone thinks you need to adhere to. The only numbers you need to worry about are the gross axle weights, tire ratings, and the gross truck weight.
Starting on or about 2013.5 all of the Ram pick up trucks have been certified to meet the SAE J2807 towing specs.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 03-22-2019, 10:44 AM   #9
You're likely looking at a pin weight of 1,400-1,700 pounds for a fifth wheel like that.
I'd think unless you run heavy, that most 3/4 ton trucks have plenty of payload to carry that weight along with driver, passengers, hitch, and some stuff in the truck bed.
Gas or diesel - both are good for hauling that kind of weight. I'm partial to diesel largely for the simplicity of fueling up at truck stops. I don't have to navigate the front gas lanes with truck and trailer; I just pull around back with the big boys.
Or, if you think an upgrade might occur- consider a 1-ton single rear wheel. You'll get more payload without a whole lot more money. That'll set you up for the next camper in the future if you so decide.
I'd only consider a dually if you think your upgrade might be a 40' monster.
Old 03-22-2019, 10:59 AM   #10
rracer5's Avatar
X2
And diesel. That'll take the "struggle" out of pulling and slowing down any upgrade you may decide on. Diesel engine brakes are your friend!
X2
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
5th wheel, truck, wheel
