05-03-2013, 05:30 PM
Need Advice - Supplemental Toad Braking Needed Or Not?
I need some advice on whether or not I should have or really need a supplemental braking system on our Tow vehicle. Here is the setup. Motorhome is a 2008 Lexington model 283GTS on a Ford E450 Super Duty Chassis. Tow vehicle is a 2007 Saturn Ion that weighs in at 2700 Lbs. Tow bar is a Roadmaster Falcon 2. The Legal requirement here in Florida is 3000 lb towed vehicle and up must have a supplemental braking system installed but with our Saturn Ion at 2700 lbs. Therefore we are "legal" at least in Florida. I have done a bit of research into these systems and have some knowledge of the older style Brake-Buddy and the newer Invisibrake from Roadmaster. They are all a bit pricey at around $1200-$1300 (installed for the Invisibrake at Camping World). Are there any other brands that I should be considering and is a supplemental braking system really needed? Thanks and I will appreciate any suggestions.
05-03-2013, 05:52 PM
On one hand if your "LEGAL" in your state of registration you'll be legal in all 50 states. That being said what will your Gross Combined Weight be with the Saturn in tow? If the Saturn in tow puts you right at Gross Combined Weight, with the camper loaded for camping, then for SAFETY SAKES I'd for sure use and aux brake sys on the Saturn.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
05-03-2013, 05:54 PM
I pull my FIAT 500 without any assisted braking system because it weighs only 2,363 lbs. Now I'm pulling it with my 37 ft Georgetown motorhome 378TS with the Ford V10 and is on a 22,000 lbs. chassis. I have power boost braking and can easily pull and stop my little toad. My max trailer hitch is 5,000 lbs. Now I have over 16,000 miles and have travelled almost 100% of the time with the toad.
Now with that information you have to decide how your rig pulls the car on the highway and are you able to stop safely with your brakes.
Unofficially with your rig I wouldn't have any problem towing it without any assited brakes.
05-03-2013, 06:37 PM
What do these ratings mean on our 2008 Lexington?
Can someone tell me what the different weight ratings are on my 2008 Lexington 283GTS. The ratings are as follows;
GVWR - 14500
GAWRR - 9500
GAWRF - 5000
UVW - 12500
GCWR - 20000
Thanks again
05-03-2013, 06:43 PM
Phat Phrog Stunt Crew
I tow a Ford Focus at around 2900 lbs. I use the Brake Buddy, older style. I like the added safety of having the braking system and some do not. As far as price, I bought mine off of Ebay for about 1/3 or original price. You may want to check there and peruse the classified area of this forum and other forums i.e. IRV2. They have a large classified section over there.
As I said earlier, this is a personal thing. But, I don't leave home without my Buddy!
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
05-03-2013, 07:01 PM
GVWR - 14500
GAWRR - 9500
GAWRF - 5000
UVW - 12500
GCWR - 20000
Thanks again
Everything you wanted to know!!!
The RR-Right Rear, LR-Left Rear, RF-Right Front, LF-Left Front
GVW: Gross Vehicle Weight
GVW Includes, Curb Weight, Cargo Weight, Persons weight
Gross Vehicle Weight (GVW) is the actual weight of the fully loaded vehicle or trailer, including all cargo, fluids, passengers, and optional equipment, as measured by a scale.
GVWR: Gross Vehicle Weight Rating
Gross Vehicle Weight Rating (GVWR) is the maximum number that the GVW or GTW should never exceed. GVWR is applied to trailers as well as vehicles, but you may see this rating referred to as the Maximum Loaded Trailer Weight
GTW: Gross Trailer Weight
GTW Includes, All GAW's, Tongue Weight or King Ping Weight, Weight on all deployed jacks
Gross Trailer Weight (GTW) is the same as Gross Vehicle Weight (GVW) when referring to a trailer. While GVW can be applied to tow vehicles and trailers, GTW makes it clear that we are speaking of a trailer.
GCW: Gross Combination Weight
GCW Includes, GVW of tow vehicle, GVW of towed vehicle
Gross Combination Weight (GCW) is the actual weight of the fully loaded tow vehicle plus the towed vehicle (trailer, car, boat, etc.), including all cargo, fluids, passengers, and optional equipment.
GCWR: Gross Combination Weight Rating
Gross Combination Weight Rating (GCWR) is the maximum number that the tow vehicle GVW plus towed vehicle GVW (or GTW) should never exceed.
GAW: Gross Axle Weight
Gross Axle Weight (GAW) is the actual weight placed on a single axle. Assuming a well-balanced vehicle, the GAW is then evenly distributed to all tires on that axle.
GAWR: Gross Axle Weight Rating
Gross Axle Weight Rating (GAWR) is the maximum number that the GAW of a single axle should never exceed. You may see the more specific RGAWR, when referring to the rear axle, or FGAWR, when referring to the front axle.
Tongue Weight or King Pin Weight
Tongue Weight (also called Tongue Load) is the actual weight pressing down on the hitch ball by the trailer. The recommended amount of Tongue Weight is 10-15% of the GTW.
Curb Weight
Curb Weight Includes, Vehicle weight with standard equipment only, Full fuel tank weight, Full fresh water tank(s) weight, Full propane container weight, Equipment fluids weight
Curb Weight is the actual weight of a vehicle or trailer including all standard equipment, full fuel tanks, full fresh water tanks, full propane bottles, and all other equipment fluids, but before taking on any persons or personal cargo.
Dry Weight
Dry Weight is the actual weight of a vehicle or trailer containing standard equipment without fuel, fluids, cargo, passengers, or optional equipment.
UVW: Unloaded Vehicle Weight
UVW Includes, Vehicle weight as manufactured at the factory, Full fuel tank weight, Equipment fluids weight
Unloaded Vehicle Weight (UVW) is the weight of a vehicle as manufactured at the factory. It includes full engine and generator fuel tanks and fluids, if applicable. It does not include cargo, water, propane, or dealer-installed accessories. Be aware that some manufacturers weigh each unit to determine UVW, while others provide only the average or estimated weight for each model.
Cargo Weight
Cargo Weight Includes, Personal cargo weight, Optional equipment weight, Tongue Weight or King Ping Weight
Cargo Weight is the actual weight of all items added to the Curb Weight of the vehicle or trailer. This includes personal cargo, optional equipment, and Tongue or King Pin Weight.
Payload
Payload Includes, Cargo Weight, Persons weight
Even though it does not include an R, Payload is a weight rating. It is the maximum weight that persons plus cargo should never exceed.
FROG Member
05-03-2013, 07:45 PM
Now you also have to take into consideration on your GVW passengers, fuel, water and all the junk you bring along.
Multiply your water and a full tank of fuel by 8.33 lbs per gallon.
Here is a way to find out what the actual states laws are for towning.
http://www.readybrake.com/state_laws.html
05-03-2013, 08:18 PM
All depends on where you are. All states are listed in Trailer Life Directory among other places. They indicate when Trailer/Toad vehicles must be fitted with TV operated brakes. Some are 1K, 2K or 3K max before brakes must be fitted. Your M/H has plenty of capacity, limit will be the hitch fitted. Most class C are fitted with 3500# hitches. These State liimits are not the same as tow ratings of the vehicles doing the towing.
05-03-2013, 09:07 PM
Hitch rating
The hitch rating on the Ford E450 Super Duty chassis that this motorhome is built on is rated at 5000 lb. So you think the chassis weight rating and 5000 lb hitch rating should be sufficient to tow the 2700lb Saturn Ion? Thanks
05-03-2013, 10:02 PM
Your tow figures look more than enough, just checked FL. Requires brakes at 3000+ lbs. Look good to go.
05-03-2013, 11:09 PM
Lindy, I did some reading and what I am seeing, your first statement may not be true. From what I found, you have to observe the towing laws in the state you are traveling in. The laws can change when crossing any state line. For instance in Mississippi, the tow weight is 2000 lbs and over, you have to have brakes in the towed vehicle. Also, max tow speed is 55 mph.
FROG Member
05-03-2013, 11:11 PM
Was that commercial requirements or private?
05-03-2013, 11:17 PM
Turbs, from what I could tell it is for Private. See this link and read the first paragraph.
Please correct me is I am reading something wrong.
State by State RV and Towing Laws
FROG Member
05-03-2013, 11:27 PM
I would have to agree with you.
Legal in your state doesn't necessarily mean legal in others.
05-04-2013, 10:29 AM
Wanderluster
Lots of controversy whether you "need" a supplemental braking system or not. One question you could ask yourself is would you rather be hit in the face with a baseball thrown at you by a 5 year old, or a major league pitcher? It's the same ball, same weight(?), same everything so what's different? Why not consider your toad to be that baseball, and then think of all that free weight rolling down the road with no brakes of it's own, and imagine the forces put on your towing vehicle with a panic stop. Your state may require a brake-away system to apply brakes if the vehicle comes loose. Check with your chassis manufacturer too as several specify supp brakes over 1500 lbs, even with a class IV hitch.
I hope you will read and consider the information presented here... The Physics of Towed Vehicles
The truth is that most states require you to be able to stop in a specified distance at a predetermined speed. If you can do that and you feel comfortable with your decision, nothing anyone will say will change your mind, only experience.
05-04-2013, 07:25 PM
This is from our 2010 E-450 Owner's Guide, page 186, in the section Tires, Wheels and Loading, in the paragraph on Trailer Brakes:
The braking system of the tow vehicle is rated for operation at the
GVWR not GCWR.
You probably need brakes on anything that you tow with a Class C regardless of the state law. The Ford E-450 Class C chassis brakes are not rated to handle as much as it can tow. The E-450 has the heavy duty components for the power train to tow the weight but the brakes are only for the gross weight of the chassis (14,500 pounds for ours), not the gross combined weight (20,000 pounds for ours). You can only meet this if the total weight of your empty coach, everything in it, and whatever you tow are still below the gross vehicle weight rating. Our 2011 model year coach has a cargo carrying capacity of about 2500 pounds, so with people, gasoline, and lots of stuff, we're near gross without a toad.
I see in the 2013 Sunseeker brochure that they have increased the GCWR to 22,000 pounds, but didn't increase the GVWR, so they can tow more but they won't stop any more.
Get a braking system for your towed vehicle. Some day you'll need to make a panic stop and will want all the help you can get.
05-04-2013, 09:21 PM
Anacortesians
A friend with a 38' gasser (I didn't know there were any that big) tows a Honda CRV. He reckons that the proportional increased weight of the CRV in the combined "train" weight is so small as not to need aux braking.
We haven't embraced the "toad" community yet, since our daily driver (an 03 Kia Sedona) weighs 4800 pounds and would need over $3200 spending on it to make it flat towable. The chances of us finding a dolly that could handle a 4800 pound FWD car that weighs less than 200 pounds are so slim as to be negligible. The hitch on the MH is rated at 5000 pounds. The Sedona is our only vehicle other than the MH.
We've been toying with the idea of finding a dirt-cheap car of a brand nobody wants (like maybe a Yugo or a Renault) just to use as a toad. I wish I'd kept our Renault 18i wagon that we owned about a decade ago, but DW can't drive a stick-shift. I've been looking at the Saturn LW, a wagon with a 3-liter V6, but DW is leery of vehicles from defunct manufacturers. My experience many years ago with a 1958 DKW has blackened her view of "weird" cars.
Can anyone confirm whether the LW series Saturns fit the general category that "all Saturns are flat towable without any mods required?
Still trying to figure the best way to proceed.
Frank and Eileen
No longer RVers or FR owners
05-04-2013, 09:32 PM
If you are interested in flat towing send me a pm as I have a very nice towbar I would sell all you would need is the base plates for you toad. I spent bout $1400 to have it intalled and I would take much less than that.
F-350 Lariat 6.7 Powerstroke
2014 Heritage Glen 356QBQ
05-04-2013, 10:21 PM
The weight of your saturn with a tank of fuel is almost 2900 lbs. You should take the Saturn to a weight scale and have the weight checked. The curb weight is listed at 2788 lbs. If by change you were to put some items into the car you could be over the 3000# limit.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
05-05-2013, 07:16 AM
Thanks all for the suggestions- Now which Aux braking system would be the best?
I have been convinced from the comments that a supplemental braking system is the way to go. Now which one? The Roadmaster Invisibrake looks good but are there others just as good?
