Old 02-03-2019, 11:41 AM   #1
justpassinthru's Avatar
Need Ford receiver hitch help please
Hi Guys just bought a 2019 F250. Any the receiver on of the hitch is 2.5 inches and my hitch and ball is a standard 2 inch bar as most are. I contact ford and they said all 2019 f250 now come standard 2.5 inch receiver ends to allow more towing hitch weight. Has anyone else run into this? And what is the solution. Thanks for all any anyone experiences. Thanks Jim
justpassinthru is offline   Reply With Quote
Old 02-03-2019, 11:44 AM   #2
BandJCarm's Avatar
Walmart or any parts store has an adapter. My Chevy even came with one. A sleeve you put inside the 2.5" to allow 2" to be used.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 02-03-2019, 11:45 AM   #3
007matman's Avatar
What he said...
007matman is offline   Reply With Quote
Old 02-03-2019, 11:58 AM   #4
Iíd check with the dealer. The adapter sleeve should have come with the truck.
spydunks is offline   Reply With Quote
Old 02-03-2019, 12:02 PM   #5
Ok thanks. But any idea of a brand part number etc for the sleeve reducers Was told the 2019”s don’t come with the factory sleeve reducer
Old 02-03-2019, 12:07 PM   #6
Our F350 also came with and adaptor.
Depending on the weight you intend to haul, you may find this article interesting.
https://www.etrailer.com/question-185917.html
As far as the reducer goes, just ask the parts guy at Walmart, Harbor Freight or similar store what they have in stock.
It'll look like this:
https://www.etrailer.com/Hitch-Adapt...rt/C45405.html
Skip12 is offline   Reply With Quote
Old 02-03-2019, 01:25 PM   #7
Who Dares, Wins
doc73's Avatar
My truck came with a sleeve. At the time I was using an equalizer hitch so I got a 2.5" drop hitch so I did not need the sleeve. It tightened up things and I found it was wearing the hitch locking pin less.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 02-03-2019, 01:32 PM   #8
Denver To Yuma In 90 Days
Mine also came with the sleeve adapter...but you can't have it!
I leave it in place...with a lock on it, of course!
Anyway, you can buy one or can also get a drop down that will fit in there without the adapter, which if your trailer is really heavy would be the better option.
I think this is called a Class VI (6) receiver...
JohnD10 is offline   Reply With Quote
Old 02-03-2019, 01:34 PM   #9
Check under the back seat.
2019 Rockwood 2902WS
2019 Ford F250 4X4 CCSB 6.2 4.30
woo10-210 is offline   Reply With Quote
Old 02-03-2019, 01:52 PM   #10
primo20's Avatar
this is where mine was in my ram.
but id consider upgrading to a 2.5 draw bar for your set up. they are readily available.
2018 DURANGO 2500 343MBQ | 2017 Ram 2500 Cummins
primo20 is offline   Reply With Quote
