11-09-2015, 09:14 AM
CCRVOC
Need Headlight Upgrade for 2012 Ram
Drove 2 hours last night in driving rain storm with what seemed to be flashlights instead of headlights. I have always known the headlights are "old school" and not very bright, but last night was brutal.
Anyone have any recommendation for an upgrade?
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 1000w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
11-09-2015, 09:23 AM
I thought the headlights in my 2010 were unbelievably poor. My wife's Nissan Versa lights were much better. Switched out to Silver Stars about a year ago and noticed an improvement. Still not as good as the Nissan's however.
Harv & Deb
2015 Flagstaff 27RLWS
2010 Ram 2500 4x4 crew 5.7 Hemi, 3.73
Equalizer 1200 4 pt. Tekonsha controller
11-09-2015, 09:25 AM
I second the recommendation for SilverStars.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
11-09-2015, 09:49 AM
SilverStar Ultras.... I use them in all my vehicles that are not equipped with OEM HID lighting. Their only downside is they do not last as long as OEM bulbs. When I was using them daily commuting I averaged about a year before a bulb failure. So carry a spare pair or your old OEM bulbs for a backup.
Wayne
2024 Sunseeker 2150SLEF / Ford E-350
11-09-2015, 09:53 AM
Do you have fog lights on the truck? If you do run with them on, I run mine 100% of the time except when the bights are on.
This seems to help in provide more light at night for driving.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
11-09-2015, 09:55 AM
CCRVOC
Yes. I keep them on all the time. They help with illuminating the sides better. But they need to be upgraded also.
Sent from my SCH-I605 using Tapatalk
11-09-2015, 12:35 PM
Left Coast
Check out protection type. Made by Anzo
11-09-2015, 12:43 PM
Owner/Operator
I put the Silverstars in both the headlights and fog lights.
A world of difference for a straight substitution without having to go through the HID mods.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
https://www.forestriverforums.com/for...ons-36212.html
11-09-2015, 12:50 PM
Too old to be too smart
A common mod is to install relays with heavy-gauge wire (and appropriate fuses) from the battery directly to the headlights, using the normal electrical "supply" to simply activate the relays.
Here's a page that explains it:
Whiter Whites, Brighter Brights - Ford-Trucks.com
Also, take a look around "Daniel Stern Lighting"
Daniel Stern Lighting Consultancy and Supply
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
11-09-2015, 01:07 PM
CCRVOC
These look good and spendy.. I emailed them to see if they are plug n play or if wiring needs to be modified.
Thx.
11-09-2015, 01:09 PM
CCRVOC
RodeoGeorge
These seem like a good short term fix for under 60 bucks or so. Thx.
sliverstars yes..... go on e-bay and get after market head light assmy.....they are clear lenses ........... have them on my 98 ram and I can see better then ever now......
they have LED head light now as long as the inside of the light housing is clean... they work good too
2016 Georgetown 31b3
11-09-2015, 01:10 PM
CCRVOC
Originally Posted by SpringerPop
I did this on my 65 pony. Big difference.
11-09-2015, 01:18 PM
Absolutely, put projection in my 2010 ford F-150, Now I can see!!
11-09-2015, 01:34 PM
Canadian Member
The stock bulbs were horrible in my '09 F-150.
I tried Sylvania SilverStars and Philips X-treme Power halogen bulbs. They were both brighter but my experience was that they didn't last long. IIRC, the Philips X-tremen Power bulbs lasted less than 6 months (we have daytime running lights in Canada) and the SilverStars were only marginally better than the stock bulbs. With regular halogen bulbs, the brighter (i.e. hotter) they get, the shorter the lifespan.
I tried HID bulbs in the stock housings and got too much glare for my liking, so I upgraded to HID projectors from The Retrofit Source Inc. They made a HUGE difference but it was a bit spendy. Had a guy about 1.5 hours away do the retrofit. Total cost was around $500 to $600 CDN, but well with it IMO. If you go this route, I'd recommend name brand ballasts and bulbs like the ones they use in higher end cars, rather than their "store brand" Morimoto.
11-09-2015, 02:09 PM
CCRVOC
So if I understand correctly, the projection is just a different type of reflector assembly not necessarily a different bulb. It just directs the light better?
11-09-2015, 03:44 PM
Do us all a Favor, and ensure that you Properly Aim your Lights for whatever Squat your 5er gives your TV...
There are FAR TOO MANY Trucks out there "Beaming the Treetops" as they drive down the Road at Night. I can always tell when an Oncoming Pickup is Towing "Something", because the Headliner in the Cab of my RAM is Lit Up and my High-Beams are Flashing my Displeasure!!
Pup: '11 HW-296
TV: '09 RAM 1500 Hemi 4x4 CC
11-09-2015, 03:50 PM
CCRVOC
Thanks for the
recommendation. I wish my headlights could beam the treetops but sadly they barely illuminate the reflectors.
11-09-2015, 05:06 PM
Left Coast
Have Anzo brand in my 99 2500 Ram 4x4......Didn't need to adjust mine, were perfect. Had to loosen front bumper for more room, but didn't have to remove. Anzo's come with every thing needed.
11-09-2015, 08:33 PM
You can all so buff out the plastic lens, most parts houses have kits to get rid of the faded plastic
