Old 04-15-2016, 10:45 AM   #41
mike.t's Avatar
Millertime. Is that why you see so many tractors pulling trailers being towed off the highway all the time and the truckers can afford these repairs?
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 04-15-2016, 10:59 AM   #42
Oklahoma Proud
MillerTime's Avatar
I guess you haven't been in the trucking industry. I have and will be again. You budget repairs in to every load. Not everything leaves you on the side of the road (like injectors, most exhaust systems, and even turbos wont in all situations ) but you will have reduced power and if dot catches some of it, you wont be moving till its fixed.
I was talking about light trucks in this situation, but hd trucks break down too.
Believe what you want, but, me and alot of other guys make really good money fixing vehicles that break down and get wrecked. Everything has a service life! UPS has it down to a science and they replace parts before the service life has reached the end of its span.
Oh and being i spend hours a day on the interstate, i see hd trucks broke down and towed frequently.
Old 04-15-2016, 11:02 AM   #43
mike.t's Avatar
Happy motoring.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 04-15-2016, 11:27 AM   #44
A 350/3500 SRW is going to have a payload of ~4500 pounds, and that trailer has a hitch weight of <2200lb, so you're fine. I don't know what the tow max is on that truck, but for both the 2500 and 3500 SRW from Ram, the max is around 17k towing limit, so that trailer would be within those limits with a GVW of 16,103lb. Stepping up to a DRW will add another ~2k in payload capacity, which seems to be unnecessary for your situation. The only thing I do know about the Fords is that when I was looking back in '13, towing was always lower for the Ford than the Ram. From what I remember it was less than 15k lb for the F250 SRW.
TV: 2016 Ram 3500 4x4 mega cab w/6.7l Cummins
Trailer: 2013 Palomino Puma 27SBU
bitNine is offline   Reply With Quote
Old 04-15-2016, 11:50 AM   #45
Kenny kustom's Avatar
Only a bare bones work truck has that payload.
Towing chart states my ccsb 4wd cummins Aisin should have 3900 lbs.
Sticker says 3747.
Add 300 for the hitch
Another 500 for passengers.
A 2500 lb pin for the 5er.
Eats is up pretty quick....
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 04-15-2016, 11:56 AM   #46
Name:	ImageUploadedByForest River Forums1460739308.066875.jpg
Full tank.
Me and the hitch.
Gross of 11,700.
Leaves 2860 for family and pin.
2016 Sabre 36QBOK
Old 04-15-2016, 02:25 PM   #47
CWSWine's Avatar
I wish my payload of 4500 lbs on my F350 has 3744 payload. Some of the Rams have higher payload because they have a higher GVWR of 12,300 while Fords stuck with a 11,500 but what I have been told that will change in 2017 and Ford GVWR will be higher than Rams plus a lot lighter truck. I owned a 315RST and adding 1100 lbs to the dry weight the scales said it had a 2780 pin weight not 2200.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 04-15-2016, 02:51 PM   #48
Sticker says 3747.
I'm confusing the hundreds with the DRW. It's 5500 for the DRW (mega cab), and 4,000 for the SRW +/- 300 lb, depending on configuration. The new truck I'm about to order ('16 laramie 3500 4x4 mega cab SRW w/air & Aisin) has payload of 4130, and towing of 16,600. Per http://www.ramtrucks.com/assets/towi...ing_charts.pdf
Don't forget to factor in the full tank of Diesel (31 gallons @ 7.5lb/gal) of 232 lb.
Old 04-15-2016, 03:04 PM   #49
CWSWine's Avatar
Mine was a F350 and the website said 4150 and the payload tag on the truck was 3744. I think with the meg cab it will even be few pounds lower than mine. The 16,600 may be right but you will probably run out of payload before you run out of towing capacity.
Old 04-15-2016, 03:05 PM   #50
Fulltime family RVer
A 350/3500 SRW is going to have a payload of ~4500 pounds...
That makes me sad. My 2012 Ram DRW only has 4,300 lbs. of available payload. The newer trucks have such better/higher numbers.
If I recall correctly, payload assume full fluids.
ependydad is online now   Reply With Quote
truck
