Old 12-20-2015, 11:52 AM   #11
Ken K thanks for your input. It has the 5.7L engine with the 6.5' bed. The tires I will put on the truck are the Michelin LT Defenders E rated tires. Can you recommend me a WDH that will work with my setup that I can back up with it still being attached? I see some have said with the right WDH that I don't need the air bags, so I will do that last
Also looks like my hitch will need to be raised about 8" so the trailer will not sit to low. So need a WHD that will be raised up 8"
Thanks again,
Mike
in6seczone is offline   Reply With Quote
Old 12-20-2015, 11:59 AM   #12
northstar1960's Avatar
the Andersen works great . i have the 29 xlr and sit at about 9000 loaded and it a breeze to tow with the andersen . i have a 2500hd a bit more then the tundra but my tow specs are very close so it should work well for you
northstar1960 is offline   Reply With Quote
Old 12-20-2015, 12:06 PM   #13
Ambassador
Ken K.'s Avatar
OK then lets clear this up a little...
Originally Posted by MtnGuy View Post
This is probably the best forum to ask the questions, as towing related questions cover all trailers.
To answer a couple of the OPs questions:
The Andersen Hitch seems to work OK for heavy duty trucks pulling smaller trailers, but not 1/2 tons pulling heavy trailers. The Andersen has not been proven (at least on this forum) to transfer enough weight to the TV front axle. Consider another WDH with integrated sway control such as anEqual-i-zer 4 pt., Reese Straight Line Dual Cam, or Blue Ox Sway Pro.
Anything loaded in the cargo area of a toy hauler takes weight off of the tongue. That is why many toyhaulers have a heavy unloaded tongue weight......once cargo is loaded, the tongue weight comes down. Loading up 1100 lbs. of cooking supplies in the cargo area could take several hundred lbs. off of the tongue weight. The OP may need to tweak the placement of the cargo to get a good tongue weight of 12-15%. Of course, anything loaded in front of the axles (camping gear, clothes, food, etc) will add to the tongue weight.
If someone is exceeding the P series tire ratings, then they will also be exceeding axle ratings, as the tires should always be rated more than then the axles.
With a properly setup WDH, air bags should not be needed, and IMHO they should not be used on a 1/2 ton truck......to easy to give you a false sense of safety when the truck doesn't settle. Air bags do nothing to distribute the trailer tongue weight to the TV front axle.
OK folks there's more to consider with LT tires than just their weight capacity. As you press your foot on the accelerator you generate torque (hopefully) in the drive train, and those forces are then transferred to the ground via the drive axle, and then finally the tires. I think Mtn Guy, along with several other opinions of Rated LT tires demonstrate a gross misunderstanding of the whole scope of LT rated truck tires use/benefits in Hauling. The tires have a different rubber compounds made to resist heat build up, and then dissipate the heat better once it does build up much better than any P metric passenger tires. Other considerations in this case are that the rolling friction is reduced because of the increased sidewall ply count, and higher tire pressure this will translate to less drive train stress; this may also result in a slightly improved gas mileage. He will be hauling 4 to 5 tons with what is arguably a mid range truck, going in to curves, starting and stopping, and those 4 to 5 tons will want to keep on going in the direction they were traveling. This will put a lot of friction and lateral torque on his P metric plyless side walls(a nylon casing doesn't count as a rated ply) that his current tires just aren't designed to handle. In my opinion weight carried on the axle is the least of his worries. You need to consider that those sidewalls are made to handle the forces that the load gives back as you transport it down the road and react to conditions. So it's not just weight management but the overall safety and well being as well. It's always good when you Arrive Alive. If it were a smaller load I think I would have a different opinion, but he is nearly maxing out his trucks capacity, and needs to have the right equipment to make sure he makes it to those BBQ competitions. Also if something does happen and he hurts someone other than himself, and he was under equipped for the load he was carrying because some one on the internet said it was OK, someone could end up paying out of pocket, I don't know if you have paid for a couple of months in the ICU, but it's a hell of a lot more expensive than a set of tires.
Buy the tires...
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
Ken K. is offline   Reply With Quote
Old 12-20-2015, 12:14 PM   #14
Besides you having a (2500HD) you failed to also tell him you installed Air Bags on your truck,and you say your Tow Specs are Very close! Youroo!!
Old 12-20-2015, 12:48 PM   #15
Blackhat6mike's Avatar
Originally Posted by in6seczone View Post
I bought a new 2016 Tundra double cab yesterday with tow package. I will be using it to tow a 27'HFS hyperlite XLR toy hauler. Most tows will be around 100-250 miles. The dry weight showa 6300lbs. In the cargo area it will be loaded with 1100 pounds (BBQ smoker, stainless steel sink and generator...using this for doing competiton BBQ's) and another 600 pounds for everything else in the trailer. So I'm figuring about 8000 pounds loaded. Not sure yet of the TW, although it says it is about 800 lbs, so lets say it is 1000. Maybe someone who owns one of these trailers can let me know if this is close. I will not be putting anything in the bed of the truck. So here are a few questions I have.
Will the P series tires be enough for this truck or will I be better off going with a E series tire? Sure seems like it would be a lot safer with the stiffer sidewall and carrying the load. Are they needed?
Also does anyone have any experience with the Anderson WDH pulling a 8000lb TH? I understand some have said it will not transfer enough weight to the front axle. I have been told to put the Firestone Air Bags on it and that will help with the sag. So if I have the air bag can I use the Anderson WDH. I really don't want to unhook when I back up. Some of the BBQ competitions we do is not easy to get into.
Thanks in advance
Mike
Did your truck come OEM with "P" or "LT" tires? Every truck I've owned came with LTs. Just curious. Seems like if the truck has the towpack, it would have LTs.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 12-20-2015, 01:06 PM   #16
Blackhat it came with the P series tires. I just thought it would be way better to put the Michelins LT Defenders on the truck. My salesman said he would give me $400 for the tires I'm taking off so it was a no brainer.
Mike
Old 12-20-2015, 01:22 PM   #17
Thanks for all the replies. Well no doubt I'm getting the LT 10 ply tires.
But I really need some help with the hitch. Seems like I have read the Anderson WDH does work ok with all the trucks bigger then the 1/2 and on lighter trailers. But not so much on the 1/2 ton trucks pulling 8000 pounds.
So what would everyone recommend for pulling my 27' HFS weighing 7800-8000 pounds, with my Tundra. I will need the hitch raised about 8" to keep the truck and trailer close to being level. I really want and need a WDH that I can back up my trailer without unhooking it. When we go to these BBQ competition we are sometimes in tight areas and I don't want to have to unhook to back up.
I will put air bags on later if needed.
Thanks in advance
Mike
Old 12-20-2015, 02:11 PM   #18
MTNGUY you posted this:
Which of these hitches would you recommend?
Please consider I need a hitch that I don't have to unhook to back up. Trailer will weight about 7800-8000 pounds. Guessing TW will be about 800-1000 pounds. Hopefully the one you recommend does not have to have a lot of grease on it to keep it quite.
Mike
Old 12-20-2015, 03:36 PM   #19
A32Deuce's Avatar
I believe they answered that last question earlier when they said they could back up without unhooking. I know, a lot of information at once.
A32Deuce is online now   Reply With Quote
Old 12-20-2015, 03:37 PM   #20
CaptnJohn's Avatar
I was pulling about 8000# with a 1/2 ton for a short time a couple months ago. Bought what I believe was the safest to do the job. The Equalizer (TM) WD with sway control. Only used it twice and it now sits in my garage. It is rated 1000TW and 10,000 tow weight ~~ I tow a 5er and doubt will have use for it again.
towing, xlr
