03-09-2018, 08:59 PM
need hitch recommendations for 5th wheel
Hi everyone,
We have made the big jump from 34 ft Windjammer TT and have ordered a 41ft 2019 Cedar Creek 37RTH (14000 LBS empty). We are new to the world of 5th wheel towing. Looking for recommendations for the best hitch or ones to stay away from. Our 2017 Dodge 3500 dually has factory 5th wheel and gooseneck prep group option. Appreciate any input you can give.
Pat and Angela Malerk
2018 Dodge 3500 Diesel Dually 4x4 Aisin Transmission 410 Gear towing
2019 Cedar Creek Silverback 37RTH
03-10-2018, 01:37 AM
Always Learning
B&W Companion is an excellent hitch. I’ve had mine for the past 6 years. Absolutely love it.
03-10-2018, 01:52 AM
My business partner has the B&W as well in his Chevy Dually with a similar set up in the bed and he likes it.
03-10-2018, 08:14 AM
X3 on the B&W.
2016 Forest River Wildcat 314BHX
2019 Ford F-450 Limited DRW 6.7 Diesel
03-10-2018, 08:45 AM
B&W all the way. Great customer service and American Made.
03-10-2018, 01:14 PM
I've been using the TrailerSaver BD3, by Hensley for several years now and love it!
On the expensive side, but worth every penny as far as I'm concerned.
Much sturdier plate and jaws than you find on the typical Fifth Wheel hitch, and air ride bags incorporated into the hitch.
https://www.hensleymfg.com/product/b...h-wheel-hitch/
Mike
* 2007 Chevy 2500 HD, 6.6 Duramax Diesel, Allison Transmission, Roadmaster Active Suspension on the rear and Bullydog Tuner
* Sabre 32 RCTS 5th Wheel
* Trailer Saver BD3 hitch
03-10-2018, 01:22 PM
You didn't say if your TV is long bed or short bed. That makes a big difference in the type of hitch you need.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 30 Months on the Road Since 2008
03-10-2018, 01:24 PM
Don’t know if I’ve ever seen a short bed daully unless it’s a MegaCab Ram...
03-10-2018, 01:25 PM
X2. It is impossible to make a BEST hitch recommendation without knowing if you have a LB or SB truck
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
03-10-2018, 01:59 PM
Been pulling for over 30 years and I was concerned about the bed length issue when I moved to a short bed pickup (2500HD) pulling my fifth wheel from pulling my Airstream with my van.
While I would generally agree with the bed size affecting hitch recommendations to a certain extent, in reality I've found:
1. Many/most fifth wheels these days make "concessions" on the front cap design to accommodate the short bed trucks with curved front caps,
2. In the 75 or better times I've pulled our fifth wheel, I could count only 2-3 times when having a long bed or slider hitch would have had any benefit to me...and I've cranked her into some pretty tight spots.
A couple personal thoughts...
03-10-2018, 02:34 PM
Recently saw this one in action. If I need to get a new hitch, this will be the one
Jim & Pam
2017 Ram 3500, Crew Cab Diesel Dually
2014 Hemisphere 327res
03-10-2018, 03:58 PM
Charlie & Sue
Need Hitch Recommendations For 5th Wheel
You state your empty weight, but buy a hitch based on max weight that includes cargo. If you buy one based on the 14,000 lbs., say one that is rated at 15,000, then you will be in trouble once you get your cargo on board regardless of make and type of hitch.
I use a Curt 20 rated to 20,000 in my 3500 RAM DRW LB for my 2015 Cedar Creek that is slightly less weight and one foot shorter than yours. I like the Curt which is now looking after its second fiver. Need to grease 3 nipples periodically, but works like a charm. Certain pin boxes, such as a sidewinder type, cannot be used with the Curt 20 according to the hitch manual.
Happy shopping and happy travels.
03-10-2018, 04:22 PM
Ditto on Hensley Trailer Saver. I have a Riverstone Legacy which is 19k dry and really appreciated the built in bags when driving on rough roads in OK. It is pricey but jaws are flawless. Loading and unloading is smooth and they will work with you by allowing a credit card charge each month without interest. Also guarantee happiness with 90 day approval. Only caution is if you need truck without hitch on a regular basis it is a heavy beast. I load and unload by hooking it to trailer and lifting or lowering with trailer front jacks. This is recommended method but still a chore lining it to truck when reinstalling.
03-10-2018, 04:31 PM
Bene Gesserit Rule
Originally Posted by Redheaded blue tick
Hi everyone,
I put a Reese R20 in my Silverado 2500HD Crew cab long box. Great hitch.
03-10-2018, 05:41 PM
B&W Companion for your LB. liked mine in the LB but now have a SB and the B&W Patriot slider is fantastic.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
03-10-2018, 06:38 PM
New to FR. Old to TT
5th wheel hitch
we have also made the big move up from a 34 foot Rockwood to 2018 Cedar Creek 36ck2 a little over 40 feet that should be finished being built next week, and after a lot of looking and talking to current owners have decided to get the Andersen aluminum ball mount hitch. It will only weigh about 36 lb, Rated at 24,000 lbs GTWR and 4,500 lbs tongue weight and makes hitching at an angle or slope a lot easier.
2018 GMC 2500 Denali HD ,Duramax with Allison trans.
2019 Cedar Creek 36ck2
03-10-2018, 07:20 PM
Curt 5th wheel
You have the Puck system in your truck which works great. I bought a Curt 5th wheel that is rated @ 25,000 lb capacity way more then I need but it is great and cheaper in price then the B/W but I believe it is better and it really is great.
03-10-2018, 11:55 PM
Bene Gesserit Rule
You can add a hum V and HIV along with the TV and UV plus an OD TT which is OW and just for added fun, PTSD. But that's probably a bit much, IMHO, OK?
03-11-2018, 03:28 PM
I rigged a block & tackle to the ceiling of my garage, with cables that hook on to 4 bolts I put through extra holes on the side...back the truck in the garage, hook up the cables, pull the pins, raise it a bit while my wife drives the truck out...then lower the hitch down on to a dolly where I can store it anywhere in the garage.
Like my process!
03-11-2018, 05:31 PM
Bene Gesserit Rule
Like my process!
Me too, on all items, ratchet hoist, chains, dolly, only I drive the truck, always. I also need a big rubber mallet for coaxing the thing back into its slots when refitting.
