At this point the trailer is reading level (doesn't look it because of the driveway) But the Level says it is center dot.. The truck measurement from ground to center of top fender measured 41 " unloaded..Connected it measures 41" on the dot still However you see my bars are not level.. I think I may need to rotate the ball forward a bit and maybe go up a link on my chains.. thoughts? This hitch does not use washers, it has grooved spacers that hold it.
I only have a little bit of time to get it set up so thoughts appreciated asap!!
Actually I'm looking at a youtube video of the same reese hitch with the "trunion bars?" setup (not sure if I spelled that right) and they aren't level either, So I may be good?
