Old 01-29-2019, 05:28 AM   #1
Coachmen Clipper Fan
PFLOYD75's Avatar
Need Weight Clarification, Please....
Hello to All:
Well, the 2019 camping season will be starting off much sooner this year for me than usual as I'll be pulling my TT down to Daytona, FL starting February 8th for 10 days for the NASCAR Speedweeks events there, followed by seven more days immediately following, at the Atlanta Motor Speedway.
But I digress.....
First, my apologies for dredging up this type of thread again, which I know has been discussed ad nauseum here, however, I have searched and cannot find a specifically-related thread to my own questions / issues.
I had some major changes made to my Coachmen Clipper 17FQ over the winter, most specifically flipping the axle to give me greater ground clearance and I was able to upgrade from two (2) 13-inch wheels and tires to two (2) 14-inch wheels and tires (ST205/75R14) with 2,040 lbs. each weight-carrying capability.
I decided to do the Cat scales weighing of my trailer for the very first time. So, I read so many posts on here, other online articles, watched many Youtube videos, et.al. and felt like I knew what to do to properly weigh things out.
When I arrived to do my weighing, the lady running the scales told me I could not unhook my TT so that just the tongue jack alone was on the scale for my first weight measurement--to help determine what the tongue / hitch weight would be (right?)--meaning I would weigh the trailer alone with the two-wheels axle NOT on the scale and my Expedition not on the scale either.
She said if there wasn't enough weight on the scale, it would throw her scale calibrations off. (First question: is this true?)
So, she had me stay hooked up, and roll my TV onto the first (or farthest along of three) scale with my TT on the second (or the middle of three) scale.
This combined TV and TT weight came out to read as follows:
Steer Axle: 6,720 lbs
Drive Axle: 3,500 lbs
Gross Weight: 10,220 lbs
She then had me drive off, unhook the TT and drive just my vehicle back onto the first (i.e., farthest up) scale which came out reading:
Steer Axle: 6,080 lbs
Drive Axle: 0,000 lbs
Gross Weight: 6,080 lbs
She hand-wrote that the Trailer weight is: 4,140 lbs.
So with all this said, my questions are:
Is the 4,140 lbs. equal to the GVW of the trailer?
Knowing I've added on a second battery on the tongue, a second 20-lb propane tank on the tongue, carrying my (empty) 3500W Honda generator inside the TT (no water in any tanks at all), plus ALL my "stuff" packed everywhere, am I truly exceeding the sticker-listed GVWR of 3,518 lbs by 622 lbs?
How can I determine what the tongue (hitch) weight is given the weight measurements listed above?
Does this mean that the GVAW + Tongue / Hitch weight combined is 4,140 lbs so that I am already exceeding the combined tire weight-carrying capacity of 4,080 lbs.?
Do I need to off-load some things from the TT to the TV before I start my 1,200 mile journey from Michigan to Florida next week?
Sorry for the long-winded post but this is all been keeping me up at night and after having two tire blowouts on the way to Watkins Glen last August--on the same day! (but I was fully loaded with 30 gallons of fresh water too)--I'm a bit paranoid thinking I'm already carrying too much weight for both the TT axle AND the two brand new tires...
I'd appreciate all you camping veterans' thoughts and comments out there as to what I should do to get closer to my GVWR of 3,518 lbs. (And does this GVWR mean the GWA weight + tongue / hitch weight combined?)
Thank you all in advance!
Mark R. Wagner
PFLOYD75 is offline   Reply With Quote
Old 01-29-2019, 06:03 AM   #2
The simple way to always know what your tongue weight, is to purchase a Sherline Tongue Weight Scale.
I wished Iíd gone camping sooner in life.
Traveling Circus is offline   Reply With Quote
Old 01-29-2019, 06:44 AM   #3
Oaklevel's Avatar
Never unhook your trailer on the scale !!!!!!!!!!!!!!!!! This should be common sense. Sorry to be so harsh.
The big trucks need the scales to make a living never tie them up. As far as throwing her calibrations off I have no idea but CAT scales guarantee the truckers an accurate weight in court.
https://catscale.com/how-to-weigh/
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 01-29-2019, 06:51 AM   #4
it's pretty obvious the trailer weight is the 4,140 she hand wrote.
now look at the steer axle readings. i'm assuming here that both of the truck axles were on the first weigh pad (the steer axle). this seems to be the case as when you weighed the truck alone all the weight was on the steer axle pad. so in the first weigh there was 3,500 lbs on the drive axle pad. this has to be the weight of the trailer being carried by its axle. so take the 4,140 gross weight of the trailer and if 3,500 lbs of it is being carried by the trailer axles, then the pin weight is 640 (4,140 less 3,500).
i'll leave it to you to use these actual weights and compare them to the various weight ratings. you seem to understand them.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 01-29-2019, 06:52 AM   #5
Oaklevel's Avatar
Yes, the capacity of the trailer appears to be 3518 lbs you have 4140 lbs trailer weight. 4140 lbs is the actual weight of the trailer so you are way overweight. Not surprising that you are blowing tires.l You need to lighten your load over 600 lbs
Some one please correct me if I am wrong ??
1966 Mustang GT
1986 Mustang SVO
Old 01-29-2019, 06:54 AM   #6
Your weogh slip shows your trailer axle as your drive axle
It would have been better if you stopped both times with only your front axle on the first pad, your drive wheels on the 2nd pad and when hooked up- your trailer axle on the third pad. You may not have enough length to do this.
'15 Salem 28 RLDS
'17 Ram 1500 ED airride
Predator 3500
H20loo is offline   Reply With Quote
Old 01-29-2019, 09:09 AM   #7
Head Rambler
According to the Coachmen site the 17FQ has a GVWR of 3635 lbs and it actually weighed 4140 lbs, so that puts you 505 lbs over weight.
Even though you upgraded the tires, did you upgrade the axle? If you didn't I suspect that the axle is a 3500 lb axle so you're right at the max at 3500 lbs weighed. I'd be concerned about the springs and hanger hardware. Theoretically they should handle it, but we know how they like to design things right on the edge.
Gotta go campin!
Old 01-29-2019, 09:23 AM   #8
Oaklevel's Avatar
Then scroll down........................ to RVs
Check their site out and weigh by these instructions. Your TV (Truck) should have been on two pads to have a front and rear axle weight when solo. Also the weights for the combined (with trailer) steer axle and drive axle (rear) seem odd in she should have............... the set up should have been on 3 plates the TV on two the trailer on one.
I do she why she did it the way she did though. It gives you the trailer weight and the TV weight (loaded and without trailer).
Regardless the trailer weight is over capacity. Those numbers will not change.
Check out CAT scales web site
1966 Mustang GT
1986 Mustang SVO
Old 01-29-2019, 09:38 AM   #9
B and B's Avatar
You answered your own question. You are overweight. Maybe put generator in the truck bed and pack stuff in bins. Other options is to buy a new trailer. These are light weight Travel Trailer not designed for excessive weight.
B and B is online now   Reply With Quote
Old 01-29-2019, 09:49 AM   #10
MillMitch's Avatar
In answer to your original post, yes, you may want to move some heavy items into the TV. I am assuming you have the payload with the Expedition since the TT tongue weight is around 600#. I don't know who's traveling with you, but I would put gear as far forward as you can so all the weight isn't sitting on the rear axle.
Good luck
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
cat, weight
