Old 06-13-2016, 06:49 PM   #1
NEVADA J Endorsement
So I went in today to do the vehicle inspection portion of my J endorsement test.
They refused to give me the driving test as they stated that my truck was not rated to tow the 5th wheel.
Truck: GMC 3500 5th wheel rated at 16,900 pounds.
Trailer: GVWR 16,500 pounds
They refused because the truck has a GCWR of 24,500 pounds and a GVWR of 11,000 pounds. They don't believe that truck is rated to tow the trailer as the GVWR of the truck and the GVWR of the trailer exceeds the trucks GCWR.
Additionally if I get another truck with a higher GCWR I need a Class A license instead of the J endorsement as the GCWR would exceed 26,000 pounds (11,000 + 16,500 = 27,500lbs)
Personally this doesn't sound correct to me. As the pin weight would be on the truck (say 3500lbs) you could never load the truck to the GVWR and still tow a trailer. It would be loaded to 7,500lbs. At this weight the GCWR would be below the trucks GCWR as well as below the 26,000lb limit for the class A vs. J endorsement.
Is my logic flawed?
Of course they pulled this information from the trucks user manual. The tester stated that some manuals only show the tow rating and don't show the GCWR at all. When that is the case they only look at the tow rating as they don't really care about the GCWR. But as the information is in the manual they can't ignore it.
So either I buy a new truck or I find a manual for the truck that doesn't show the GCWR.
2015 GMC Sierra 3500 Duramax
2017 XLR Thunderbolt 340AMP
taylorjw0831 is offline   Reply With Quote
Old 06-13-2016, 07:11 PM   #2
Their flawed logic is assuming both vehicles will be at max (GVWR). The whole point of GCWR is to give an overall max combined.
If you aren't over either vehicle's GVWR and you aren't over the GCWR, you are in the right. Unfortunately, you can't prove it unless they weigh you... and you can't fight city hall.
What is with a special endorsement for an RV anyway?
325BH is offline   Reply With Quote
Old 06-13-2016, 07:21 PM   #3
Kenny kustom's Avatar
You will be at, or over the gross of the truck. So, they are right there...
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 06-13-2016, 07:28 PM   #4
BandJCarm's Avatar
Your truck would have to weigh at 8,000 to spec out for the max trailer weight. It probably does, and the trailer is probably not max weight, either. But if both are loaded to capacity, they are correct.
But I never heard of a J endorsement, so..............
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 06-13-2016, 07:42 PM   #5
So basically as the trucks GCWR is 24,500 and its GVWR is 11,000 a person could never tow even close to the trucks 5th wheel max tow rating of 16,900 as they assume that the truck is always fully loaded.
Old 06-13-2016, 08:06 PM   #6
Georgia Rally Coordinator
aceinspp's Avatar
Ya what is a J endorsement? Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 12
Old 06-13-2016, 08:06 PM   #7
Who Dares, Wins
doc73's Avatar
Pretty much...
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 06-13-2016, 08:08 PM   #8
Who Dares, Wins
doc73's Avatar
Sounds similar to our (PA ) non-commercial DL. Needed if the GVWR and trailer is over 26,000lbs combined (and the trailer is over 10,000lbs).
2015 ChevyHD D-Max
Old 06-14-2016, 01:55 PM   #9
Off to buy a (another) new truck.
Old 06-15-2016, 10:15 AM   #10
Name:	ImageUploadedByForest River Forums1466003617.920473.jpg
So picked up this monster yesterday.
Note that if you live in Nevada even this truck is not rated to tow the larger XLR Thunderbolts (even though the tow rating is ok). What a cluster.
