Old 09-15-2015, 01:54 PM   #21
lynn brownlee's Avatar
There is no discussion, if you have a choice go with the cummins, I did and it is a different world, nothing pulls like diesel
lynn brownlee is offline   Reply With Quote
Old 09-15-2015, 02:05 PM   #22
Georgia Frog Rally 2018
aceinspp's Avatar
Originally Posted by KenHwy61 View Post
My 2012 Chevy 2500 6.0 gas averaged about the same 11-13 mpg. That is a believable figure. 14-15 maybe at moderate highway speeds. 18 mpg is probably unrealistic out of a V8 of that size in a truck as heavy as a 2500/3500.
You got to remember more tech since your truck was built. Non towing I get 19mpg with 4.10 gear and 65 mph. My 2010 dully only got 12mpg. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 09-15-2015, 03:41 PM   #23
ryand's Avatar
I got a feeling I already know the answer to this but want some feedback....usually for my job I like to try and keep a vehicle to at minimum 200k to avoid spending money recklessly. I have not been burned yet. My last "truck" before the ram I had 225,000 miles. Mostly highway. The only thing that is keeping me from hanging on to the 2011 1500 is that I have towed with it and been hard on it more so than any other car/truck I have had. It's been good to me other than tires and oil changes. Have not even put front brakes on it yet...they are getting close. I know that the oil burners last longer but are also higher in repair bills. What are the thoughts of keeping a cummins ram beyond 300k and towing with it regularly?
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 09-15-2015, 03:49 PM   #24
It is very hard to justify a diesel as a casual user. I had diesels for several years and pulled 12000+ fifthwheel Toyhauler 2000 to 3000 miles a year. Had 05 Ram 3500 and have retired and decided to downgrade to 2500 Ram Hemi. It is fine empty, and gets 14 to 15 around town and 18 to 19 rural and 16 to 17 interstate. Towing is another story. Dropped to 7 to 8 towing Fifthwheel and 12 to 14 towing small enclosed Motorcycle trailer. Towing the Fifthwheel it will downshift ever hill. Pulled to Yellowstone with it about 5000 miles round trip in 14 and it did ok if you didn't mind long climbs at 50 mph at 4500 rpms. Did find on long rolling hills to just lock trans in 4th which is direct drive as 5th and 6th are both over drive. Also picked up solid 1 MPG. Doesn't sound like much but at 7 MPG going to 8 makes a difference. It also didn't shift up and down nearly as much. I had two 900 lb. Motorcycles in the toyhauler also. If all the above is acceptable then the Gas burner even the 6.4 is ok. The 4.11 gears would be very helpful also.
Son in law, Daughter and grandson was also traveling with us. This year we went to Virginia and back through Smokies. Big difference as Son in law bought new Ford 2500 Platinum Diesel. It towed in 6th gear and seldom kicked down and got 12 mpg below 65 and around 10 at 70. Still had same load. Doubt I will hook the gas burner to it again. Not only is the go power so much better and the economy, but the stopping functions and decel is now a necessity as far as I am concerned. Incidently the Dodge and GM will do the same thing just don't tell son in law.
Get what you want. I agonized over getting the gas burner and regretted it. Spoiled I guess. The handling of the diesel is far better than the gas in my opinion as the gas is much lighter on the front it gets pushed around more in cross wind and passing other vehicles. Never bobbled the diesel.
Ke5rbd is offline   Reply With Quote
Old 09-15-2015, 04:12 PM   #25
I've run duramax and Ford diesels sense 2003 and I'm thinking Ecoboost Ford next time. My 5th wheels are getting much lighter and gas is now usually cheaper then diesel. Also if I keep the truck beyond the warranty the diesels are wicked expensive to repair.
Steve Ulman is offline   Reply With Quote
Old 09-15-2015, 04:30 PM   #26
KenHwy61's Avatar
The Cummins will run a very long time. There are Dodges with over a million miles. (see link) The RF68E transmission is solid, I recently drove one with 275K on it but probably is at the end of its life. HD trannys are expensive to replace as are injectors, pumps and other diesel components. Towing a heavy RV is not cheap no matter how you look at it.
Cummins High Mileage
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 09-15-2015, 05:05 PM   #27
2015 Dodge 6.4 410 rear end.
We bought our BIG Horn in February. Took our first long trip this summer Goshen Rally. We put around 4000 miles average 12.4 miles per gallon. Has a K & N filter. We pull a 2012 Flagstaff 30ft. 85?? rkws we went to goshen,indiana state fair,Cincinnati,Columbus, Davis WV, Tennessee then back to Geogiia
tcorl is offline   Reply With Quote
Old 09-15-2015, 05:23 PM   #28
ryand's Avatar
New 2500 6.4 or ????
Thanks for all the info folks. For me, towing MPG is a non issue as we only take one big trip a year, all others have been 1 tank even with the current set up that gets 6-8 mpg with trailer in tow. I am more looking towards the more stable platform to pull with and the heavier duty aspect that the 2500 brings both while towing and just traveling. I still am undecided as there is conflicting info even on this thread about empty mpg. If I can get close to my mileage now with the 6.4 I wouldn't hesitate. Still have some homework to do but getting closer. Either way, 2500 is in my future just because no matter what mill it It has. It would handle pretty much any bumper pull I can find. These days, with kids the travel trailer seems to be the best option for our budget and layout as they get older. Even though my camper is small compared to a lot of the others, I am close if not over payload when towing. 1500 and 2500 I am told are night and day.
Old 09-15-2015, 07:03 PM   #29
I just checked my computer on the truck.. I actually average 13.9 miles when not towing. Also for the rig in my signature... I have 2994 payload capacity with the 6.4 hemi, crew cab and 4 wheel drive
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 09-15-2015, 07:27 PM   #30
JnJ in TX
I have a 2015 Laramie with the 6.4 Hemi, 4:10 rear end and 20" tires. Pulls great with plenty of power. I never thought I would do this but I bought the extended warranty from Mopar - no mileage limit and no time limit (I plan on keeping this truck for a while). Even with the 4:10 rear end, the gas mileage is good. I like this truck.
JoandJames is offline   Reply With Quote
