Old 03-19-2012, 07:58 PM   #11
acadianbob's Avatar
Good luck. LEt us know how this turns out.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 03-19-2012, 08:15 PM   #12
BOBFIDY's Avatar
What would happen guys if he hooked up the WDH 1 more chain link higher?. Might that move some more weight to the front of the truck and help?
Or maybe the bars are not rated high enough?
Just a couple thoughts.
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 06-04-2012, 10:08 PM   #13
VacaBill's Avatar
Smile Rockwood 2703SS
I wanted to update my posting. Weighed the unit, only 440 lbs on the hitch, water tank empty, 620 lbs water tank full, still only about 9% for hitch weight.
Confusing because it handled worse with the water tank full. Removed the spare tire from the back bumper and that actually helped. I am seriously thinking of taking the trailer into an alignment shop! I am also loading the trailer front heavy with our gear.:signh avefun:
I have the trailer level and about equal weight on both truck axles.
I want to thank mike44460, the Hensley is what has really made towing this trailer a joy, I understand what you where saying. The improved handling and control experienced is amazing.
Thanks to All who Replied.
VacaBill is offline   Reply With Quote
Old 06-05-2012, 11:17 AM   #14
MIKE44460's Avatar
You are welcome. Enjoy and remember to grease it as they say. It only takes a short time to drop the weight bars and smear some grease around. I keep a pair of rubber gloves in the RV and a can of grease. Using a grease gun, I just don't see the grease getting to the places it needs to be when the bearing surfaces are under pressure.
Mike & Lu Anne
& our Jack Russell 'Genny'
2011 Flagstaff 831FKBSS
2011 Chevy CC Duramax Z/71
OH plate GM DMAX
Hensley Arrow
MIKE44460 is offline   Reply With Quote
Old 06-05-2012, 11:34 AM   #15
Originally Posted by MIKE44460 View Post
If you think 3K for a hitch is crazy, don't buy a Hensley. If you want to pass a semi with out thinking which way will the air push me, if you want to be relaxed and not have sweaty palms when you see a semi in the hammer lane and he is going to blow by you, if want to remind yourself there IS a trailer back there, spend the 3K.
I really, I mean really have to watch myself when I pass someone that I don't pull in to quick. It is very relaxed driving and only pushing down on the throttle reminds me there is a trailer back there, crosswinds, down hills with curves, I'm driving a sports car pulling a RV. On the long flat runs I can set the cruise at 80 and motor.
And when a tire blows from excessive speed I will venture a statement of "those da-- china bombs, I checked the pressures and they were good."
Old 06-05-2012, 03:33 PM   #16
MIKE44460's Avatar
Goodyear's made in the USA, thank you.
Mike & Lu Anne
OH plate GM DMAX
Hensley Arrow
Old 06-05-2012, 03:39 PM   #17
MIKE44460's Avatar
Let me also say, when I stop for fuel I always feel the tires to check the temperature. With the Hensley I find that both the TV and TT tires feel the same. Before the Hensley the TT were always warmer to the touch.
Mike & Lu Anne
OH plate GM DMAX
Hensley Arrow
Old 06-05-2012, 04:06 PM   #18
If they are ST tires they are only rated for 65mph max.
