Old 03-18-2012, 08:49 PM   #1
VacaBill's Avatar
Unhappy new 2703SS sways wile towing
I am towing a 27 foot Rockwood 2703SS. I have a F150 with max tow package.
10,000 pound weight distributing hitch and sway bar. Trail sway is constant. trailer tire pressure is 50 psi. They look loaded tot he max, 1760 max load.
This trailer is 6100 empty, current loaded to travel about 6800. Tows worse when fresh water tank is full. Any idea's? Tandems seem to be out of alignment by 3/16 to 1/4 inch ( not parallel ) and I think this could be part of the problem. Trailer is new, less than 1000 miles towed.
VacaBill is offline   Reply With Quote
Old 03-18-2012, 08:56 PM   #2
steeleshark2's Avatar
Not enough tongue weight is what sounds like the problem. Your fresh water tank is probably to the rear which makes the problem worse. Is the trailer level when towing? Is the wd hitch setup correctly to distribute the weight? Is your truck "squating" a lot when the trailer is on? Is your trailer loaded correctly? All of this can create this condition.
steeleshark2 is offline   Reply With Quote
Old 03-18-2012, 09:02 PM   #3
caper's Avatar
What type of tire do have on the F150 LT or passenger?
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-18-2012, 09:32 PM   #4
MIKE44460's Avatar
If you think 3K for a hitch is crazy, don't buy a Hensley. If you want to pass a semi with out thinking which way will the air push me, if you want to be relaxed and not have sweaty palms when you see a semi in the hammer lane and he is going to blow by you, if want to remind yourself there IS a trailer back there, spend the 3K.
I really, I mean really have to watch myself when I pass someone that I don't pull in to quick. It is very relaxed driving and only pushing down on the throttle reminds me there is a trailer back there, crosswinds, down hills with curves, I'm driving a sports car pulling a RV. On the long flat runs I can set the cruise at 80 and motor.
Mike & Lu Anne
& our Jack Russell 'Genny'
2011 Flagstaff 831FKBSS
2011 Chevy CC Duramax Z/71
OH plate GM DMAX
Hensley Arrow
MIKE44460 is offline   Reply With Quote
Old 03-18-2012, 09:34 PM   #5
acadianbob's Avatar
X2. The F150 can handle this trailer. Something is not right with your setup. Check your truck wheel opening measurements before and after hookup. The the WD should bring your front wheel measurement about 1/2 way back from the increase without WD. So, if your front end goes up 1 1/2 inches before WD, it should be no more than 3/4 inch after WD. And your trailer frame should be parallel to the ground.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 03-18-2012, 09:38 PM   #6
Dave_Monica's Avatar
What is your hitch/sway bar set-up?
It's suggested that you have about 13% hitch weight for good towing...that's 884 lbs if your est of 6800 lbs total is correct. The specs list the dry hitch weight at 474 lbs.
You're saying that the wheels are misaligned with the camper...how are you measuring this?
Dave
Old 03-18-2012, 09:40 PM   #7
Triguy's Avatar
Vacabill, what does the sway feel like? Is it a push-suck-pull from a passing truck or the push from a wind? If so, than some of this is normal. But it can be exasperated by a WDH that needs to be adjusted (e.g., light tongue or even too heavy of a tongue). As Bob said, the truck tires make a big difference, too.
I ask what it feels like because "sway" is a term thrown around a lot and used to mean different things. Real sway is unpredictable and can be best described as a rapid side-to-side oscillation of the trailer which increases with each swing. Very dangerous.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-18-2012, 10:30 PM   #8
Coops1's Avatar
X3 on steeleshark2's take on this. But this may be as simple as dropping the ball on the truck to level the trailer. Just so everyone knows Forest River's site shows this trailer as 32' long.
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 03-18-2012, 10:39 PM   #9
caper's Avatar
A 32' TT should have two (2) friction sway bars installed. Any TT over 28' needs 2 friction sway bars if you are using friction sway control. Also if the TV does not have LT tires the walls of the TV will flex causing the TT to sway.
Terry and Janet
2007 Ford F150
Old 03-19-2012, 06:02 PM   #10
VacaBill's Avatar
Smile I want to thank everyone for their response's!
My F150 had factory tires until about 4 hours ago when I purchased LT Truck tires, 10 ply, load rated E. While the factory tires are rated to carry the load they are only P rated with a 2 ply side wall and I had to run them at max air when towing.
Second I took my truck and trailer into a new shop this morning, his first thought was to add a second friction sway bar.
We measured the truck and trailer disconnnected on level ground and he found the ball on the truck was too low. I raised the ball one bolt hole this afternoon. Otherwise he said I had things adjusted correctly. The trailer will be in the shop for a week or two on a warrantee issue so I will see how these changes help. I also plan to go to a scale and weigh out the axles when I hook up the trailer next.
I am new to this, the trailer is 32 feet from hitch to rear bumper.
Thanks to everyone who responded, you thoughts helped me sort this out.
