Old 12-03-2010, 08:25 AM   #1
New and really want to be sure
I have an o5 Avalance Z71 4WD., GCWR is 13,000 lbs.
I am looking at purchasing (tomorrow) an 06 Signature Ultra Lite with Super Slide, 32' States 6200 lbs.
I have sway bar, tranny cooler and brake controller, am I asking too much? Would onlybe towed flat ground, no hills where I live or would travel.
Want to be sure I am safe as well as the people on the road with me.
HotRodMomma is offline   Reply With Quote
Old 12-03-2010, 11:28 AM   #2
hoffkm's Avatar
I pull a 2011 Rockwood 2901SS Ultra Lite with a dry weight of 5,500 lbs with all options, I would estimate 6,250 fully loaded (first task in the spring is a trip to the scales) with my 2007 Avalanche which has roughly the same GCWR as yours (6,000 lb truck, 7,000 lb trailer maximum). It is all that I feel safe pulling with my Avalanche and many would say that I am pulling too much trailer with my rig. My new to me Hensley Arrow helps alot with sway and stability but I am still not going to win any races with a 1/2 ton truck pulling a 31' long trailer. The Signature Ultralites are heavier trailers than the Ultra Liites (more and fancier options) and you may be pushing the limits with what you are looking at.
2014 Chevy Silverado Z71---Hensley Arrow Hitch
my other toy---1969 Camaro 396 SS
hoffkm is offline   Reply With Quote
Old 12-03-2010, 12:12 PM   #3
MtnGuy's Avatar
HotRodMomma, we probably need more information.
The trailer model #.....maybe we can find the stats from that.
The Avy wheelbase. I don't think the Avy's are as long as a typical pickup. If that trailer is 32', then you are need a fairly long wheel base to pull that safely.
You have not listed the maximum tow ratings or the hitch ratings. You can probably find the maximum tow ratings on the Chevy website by entering the engine and final drive ratio. The hitch rating should be posted by a sticker on the hitch.
If you are referring to a friction sway control bar, then that is probably not a good idea for a 32' trailer. An integrated sway control and WDH would be much more practical.
Give us the additional information, and I feel sure more members will chime in here.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
Old 12-03-2010, 03:13 PM   #4
Moderators' Assistant
bikendan's Avatar
i have an '07 2WD Avy with the 5.3 v-8 and 3.73 rear end.
it's tow max is 7200lbs. you didn't state if yours is the 1500 or the 2500, which has a bigger engine and more towing.
you didn't say what that 6200lbs. weight is. sounds like "dry" weight for a 32' TT. it'll weigh over 6500lbs. on the lot.
"dry" weight is a useless number because no trailer weighs its fictional "dry" weight.
without knowing more info about the Avy and the TT, i'd say that it's wayyy too much trailer for the Avy.
32' TT usually means 3/4 ton TV.
Old 12-03-2010, 04:20 PM   #5
If you go with the tow length you would need/want a vehicle with a minimum 160 inch wheel base, which the Avalanche is not, I'm pretty sure. (Length of trailer in feet multiplied by 5 equals minimum wheel base in inches of tow vehicle) Also if you think sway won't be a problem, drive through a thunderstorm with 50 mph gusting wind.
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 12-03-2010, 07:16 PM   #6
If the truck can handle the tongue weight you will probably be OK on flat ground. TW's can vary a lot on 32 ft trailers.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 12-03-2010, 09:07 PM   #7
Flat ground or not, the question is if you can stop the rig in an emergency situation. Doesn't sound very safe to me.
Old 12-03-2010, 09:08 PM   #8
Way way way too much trailer for a 1/2 ton Avalanche. First of all that is way too long to handle with your SUV. Second that 13K GCWR can get eaten up very fast just by the vehicle and passengers. Third you will not like attempting to tow that long with that short of a vehicle. Lastly the 5.3L if you have a 1500 based AV will not be happy trying to pull that much trailer.
Old 12-04-2010, 08:45 AM   #9
Not such a Junior anymore
Borwick's Avatar
When the wife and I first decided to get the TT, our list included models that were the "biggest" we could pull with our vehicle.
We put down the deposit, and then realized that we did this the wrong way. We were lucky that the dealer allowed us to tear up that contract, and get real.
Around Northern California, the "RV" type of camping sites are just parking lots. We enjoy "rouging" it, which means dry camping in varied terrain.
We ended up with the smallest trailer we could find that met our needs. In the end, we are happier because it's easy to tow, and we can get in and out of campsites that the larger unit could not go.
Yosemite (size restrictions), and many of the Sierra Nevada campsites around us are very hilly and snug.
You might think about this in those terms. I know the McMansion units are great, but I wouldn't consider them a "go anywhere for the weekend" kind of thing.
Dave & Tami
Borwick is offline   Reply With Quote
Old 12-04-2010, 06:05 PM   #10
Herk7769's Avatar
That has to be the best bit of advice I have seen on this Forum.
