Old 08-17-2016, 10:14 AM   #21
Originally Posted by Phenom View Post
Back in April I upgraded to a used 3/4 ton Chevy gasser. Awesome truck, but the 6.0 and 3.73 left a little to be desired when it came to hills, headwinds and anything above 3000' alt. So, decided a diesel was in future. Might as well do it now, while the gasser was worth more if I'm going to do it eventually anyhow.
Picked up a '16 2500 LT with the dmax. Love the truck. Empty I'm at 21mpg mixed driving, and the ride is even better than the 14 was. Really like it. Now the bad. About 40 miles into it, I parked, shut down and ran an errand. Came back out, start up, put it in reverse, I've got all indications I'm in reverse, but engine just revs. Back in drive pull forward try reverse again, it's all good. It does this three different times today. The last time, I revved it more and it jammed into gear and jumped back somewhat violently. Seems to only happen if it sits a few mins or more. Needless to say, it's day one, I'm irritated and in a loaner now. Very happy I was fortunate enough to be able to have the truck, but frustrated it had a problem right off. Also, I'm sure this will be a "could not duplicate" type thing.
Any dmax/Allison owners here ever experience anything similar? Trans fluid was full, and zero codes.
Could be fluid draining leaking past the converter check valve, which would take a little time to fill the converter back up. not sure how the Allison works, but just a thought
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 08-17-2016, 10:54 AM   #22
The Allison is an adaptive transmission, as in it learns how to shift the more you drive it. I know you aren't tuned, but in the ones that are, when we change tunes we should clear all the learned data in the TCM so that it re-learns how to shift appropriately for the new power level. I know that when I do a trans relearn, it will do exactly what yours did going into reverse. It will also shift hard and funny in drive. This is very short lived, as the transmission starts to learn quickly. Read the below article for more info on how to do a relearn with the Allison.
Allison 1000 transmission re-learn
If dealer cleared the TCM, they should have done the relearn procedure, but don't count on it. Won't hurt anything to do it yourself again. The Allison is a very smart transmission, but also very sensitive to electrical inputs. Do the relearn procedure and drive it. It will get smoother the more it learns about your driving habits.
Note: I'm not saying that there might not be something wrong with your truck. That's the reason vehicles come with warranties, things sometimes go wrong on the assembly line. Dealer cleared the TCM, drive it for a while and see what happens.
2006 Chevrolet 2500HD CCSB Duramax/Allison
Demco 18k Autoslide
2012 Puma Unleashed 356QLB toy hauler
Toys - CRF250X, CRF250R, CRF450R, CRF150F, TTR230, TRX250EX
rmoore0852 is offline   Reply With Quote
Old 08-17-2016, 03:17 PM   #23
Phenom's Avatar
Great info. I've had other vehicles with this, but none so obvious as this one. Judging by how it drove yesterday as I left the dealer, it was back at square one learning. You can really tell a difference from the beginning of adaptive learning process. I noticed the same from when I left the dealer on day 1 up to the point I dropped it off. Haven't had any reverse issues either.
Had to take my trailer in for warranty work today. About. 50 miles towing, averaged a little over 10mpg at 65 with headwinds and heavy rain. Very impressed. Just as I'd read all over, set the cruise and exhaust brake and let it go. It was awesome. It wasn't even trying.
Sean
'16 28DBUD
'16 2500HD Dmax
Phenom is offline   Reply With Quote
Old 08-17-2016, 03:49 PM   #24
dmdomokos's Avatar
Wow! So if I get a new trailer that weights say 3-4k more, will the transmission re-learn over time or do I need to do a re-learn? It also looks like there are 2 profiles? One for normal and one for when the tow/haul button is on?
2016 Rockwood 2702WS
2016 Chevy 2500HD Duramax 4x4 High Country
dmdomokos is offline   Reply With Quote
Old 08-17-2016, 06:48 PM   #25
There are LOTS of different shift profiles. The Allison is very smart, and a very well designed transmission. That's what happens when GM (and Dodge with the Aisin) get a medium duty and heavy duty transmission company to build a light duty transmission. You get engineers that actually know what they are doing, lol.
Anyway, with changing trailers do not need to do a relearn. The dangerous thing is when you dramatically increase power levels without the relearn. My truck is 360ish hp stock. If I load a 550 hp tune right before running down the drag strip, it will slip the transmission in a heartbeat. As long as you are not tuning the truck, you shouldn't ever have to do a relearn unless something is worked on, then the dealer should do the relearn but don't count on it. It is important to occasionally do some 3/4 and full throttle runs, just so the transmission "remembers" how much power is actually on tap if needed. If you are towing with it, no worries it gets worked hard enough while pulling the trailer.
Demco 18k Autoslide
Old 08-19-2016, 03:25 PM   #26
Phenom's Avatar
Final report on this. Nearly 500 miles on the odometer and no more reverse issues. Truck is great. Must've been a learning thing as noted above.
I'm thinking diesel is like high speed internet. You can't go back to dial up after this. Really liking the engine.
Sean
'16 28DBUD
'16 2500HD Dmax
Old 08-20-2016, 09:14 AM   #27
dmdomokos's Avatar
I've had mine for 3 weeks now. Absolutely love it. The rumors are true.
Old 08-20-2016, 02:10 PM   #28
keeprr's Avatar
I've had mine 8 months. So far 3 trips pulling 10000 lb 5er. Leaving shortly on 3000 mile trip to Virginia Beach. Can't say enough good about my 2500 All Terrain.
2016 Open Range Light 297RLS Fifth Wheel
2015 GMC 2500HD 6.6L Duramax
Days Camped. 2015: 17
Days Camped 2016: 58
keeprr is offline   Reply With Quote
Old 08-28-2016, 07:06 AM   #29
Phenom's Avatar
Derailing my own thread a little. This is a little thing so didn't want to start a whole new thread. Found this plug behind rear bumper under the bed. Any idea what it's for? I don't have the parking sensors. For those maybe?
Love the truck btw. It pains me that I'm out of town for a month training for work and can't enjoy it.
Sean
'16 28DBUD
'16 2500HD Dmax
Old 10-11-2016, 05:55 PM   #30
keeprr's Avatar
Had a weird experience with Mt Dmax while traveling back to Oklahoma. The turbo failed with only 10,000 miles on it. Dealer in Tennessee replaced it and said they had never seen one fail at such low miles. Truck did great thru Tennessee and Virginia mountains. Averaged 13.2 mph for the 3700 miles. Coming over the Appalachianso, got caught behind 18 wheeler and got slowed down to 45 on incline. Pulled out, ran 2300 to 2400 and climbed right back to 65 with no trouble. Love my Dmax.
