08-15-2016, 05:15 PM
New dmax owner, but a bad start
Back in April I upgraded to a used 3/4 ton Chevy gasser. Awesome truck, but the 6.0 and 3.73 left a little to be desired when it came to hills, headwinds and anything above 3000' alt. So, decided a diesel was in future. Might as well do it now, while the gasser was worth more if I'm going to do it eventually anyhow.
Picked up a '16 2500 LT with the dmax. Love the truck. Empty I'm at 21mpg mixed driving, and the ride is even better than the 14 was. Really like it. Now the bad. About 40 miles into it, I parked, shut down and ran an errand. Came back out, start up, put it in reverse, I've got all indications I'm in reverse, but engine just revs. Back in drive pull forward try reverse again, it's all good. It does this three different times today. The last time, I revved it more and it jammed into gear and jumped back somewhat violently. Seems to only happen if it sits a few mins or more. Needless to say, it's day one, I'm irritated and in a loaner now. Very happy I was fortunate enough to be able to have the truck, but frustrated it had a problem right off. Also, I'm sure this will be a "could not duplicate" type thing.
Any dmax/Allison owners here ever experience anything similar? Trans fluid was full, and zero codes.
Sean
'16 28DBUD
'16 2500HD Dmax
08-15-2016, 09:46 PM
Never had that in 3 different Dmax/ALLISON combos. Seems like it may just be an adjustment on the linkage for the tranny. I don't think I would like have revved it and then dropped the shifter though. Lol.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
08-15-2016, 09:57 PM
An Allison should not move if rpms are elevated off idle when shifter is going from park to a moving gear.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "25"
08-15-2016, 10:02 PM
It was in reverse already. Heard it click into reverse. Camera came on. It indicates reverse in as the gear indication. All indications were that was in reverse. I reved a little and It wouldn't move. Then revved a bit more, not thinking it would jump and it did.
Sean
'16 28DBUD
'16 2500HD Dmax
Oklahoma Proud
My old 2005 dmax we would take a minute to warm up and work properly in reverse. Some times i dropped in gear right After starting and it wouldnt move. I think mine was a little low on tranny fluid when it did it though as i had a slight leak on one of the pto cover plates.
Never had a problem with my new Gmc duramax.
08-15-2016, 10:13 PM
Take it to the dealer. They should be able to pull some codes or find a fluid low like tranny fluid.
B and B
08-15-2016, 10:21 PM
Oklahoma Proud
Its already there if he has a loaner
08-16-2016, 12:49 PM
Sounds like an internal pressure problem especially If you rev the engine and then the reverse clutch applies. Low fluid also causes low pressure
2015 274 RK LIMITED <'{{{{><
08-16-2016, 12:59 PM
I had a similar issue in a different brand of truck... It ended up being the rear end had a bad gear in it.
-Chris-
2006 Grand Surveyor 240BH
Pullrite Superglide Hitch
2013 Ford F-350 Ultimate Lariat Edition with 6.7 Power Stroke
08-16-2016, 01:01 PM
I had a similar problem, but mine did not want to go pass the 3rd grear. worst it was random, take to the dealer, but all time it was OK, until I got lucky it did it at the dealer.
Was a Pressure sensor problem in the allison transmission.
replace, and since no more problems. that was 4 + years agoo.
Jean & Lucille
2014 Crusader 325RES Touring Edition
2011 Silverado Duramax 6.6L W/Allison
08-16-2016, 01:33 PM
I just purchased the exact truck, 2016 2500HD Duramax 3 weeks ago. I have not seen the reverse issue. I have felt a few "hard" shifts while under towing load between gears 3 & 4 and maybe 4 & 5 while downshifting.
2016 Rockwood 2702WS
2016 Chevy 2500HD Duramax 4x4 High Country
08-16-2016, 01:48 PM
No issues with mine. Make sure to let us know the resolution.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
08-16-2016, 01:54 PM
I will for sure. I'm getting a little more po'd by the minute as it's taken them till now to look at it. You'd think when someone brings back a truck that costs this much the same day as its purchased with a fairly major issue that it may get some priority.
Sean
'16 28DBUD
'16 2500HD Dmax
08-16-2016, 02:42 PM
Oklahoma Proud
I worked for one of the largest GM dealerships in the okc metro area for years, our service dept. had about 30 techs, but only 1-2 heavy line diesel and hd truck techs. If they are in the middle of a huge fuel system repair, turbo job etc, you cant expect them to drop everything else and get right in the middle of another big job. That increases the likelihood that a mistake is made on the first job.
You will get a much better job if you dont rush it.
I agree this sux for you, but you wont be any better off if you have to have it redone numerous times because they were rushed.
Good luck!
08-16-2016, 02:47 PM
Good luck!
Good insight. Thanks.
Sean
'16 28DBUD
'16 2500HD Dmax
08-16-2016, 05:36 PM
They re-flashed to TCM to knock out the learned stuff, checked fluid, tried to recreate the problem. No luck, so I picked it back up. We'll see what happens.
Sean
'16 28DBUD
'16 2500HD Dmax
08-16-2016, 06:02 PM
Hang in there, you are gonna love the truck. I pull a 10000 lb 5er with my GMC Dmax and can't say enough good about it. Travel numerous short trips in Oklahoma and it almost never comes out of overdrive even when we went over the Arbuckle 's. Leaving for an East Coast trip and looking forward to the Tennessee hills and Appalachians.
2016 Open Range Light 297RLS Fifth Wheel
2015 GMC 2500HD 6.6L Duramax
Days Camped. 2015: 17
Days Camped 2016: 58
08-16-2016, 06:09 PM
Georgia Rally Coordinator
Don't know what year of 3/4 ton but newer never came with 3.73 most with 4:10 gear. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
08-16-2016, 07:39 PM
That what I thought too. My '14 was an oddball. Per the code in glovebox, I had the 3.73. Also could tell by the RPM at 70 in 6th.
Drove some tonight. No issues. Really like the truck. I finally put my foot into a little. That's a little different than the 6.0.
Sean
'16 28DBUD
'16 2500HD Dmax
08-17-2016, 12:45 AM
I love my 2015 Duramax. 17000 miles and no warranty issues. It is an awesome tow vehicle. All Duramax pickups are 3.73 fears for 2015 and 16. Not sure on gearing for older models.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
