Old 08-25-2013, 06:19 PM   #11
Thanks for the advise everyone. I am going to get my new TT this week and just want to make sure I have everything ready to go.
ffwood is offline   Reply With Quote
Old 08-25-2013, 06:49 PM   #12
mini-me's Avatar
We have the E2 2 point sway with friction anti sway. Well we know that now anyway! When we bought it the dealer sad it was Weight distribution only. We didnt think we had anti sway, last trailer was little anyway. Fast forward to new 2109s. First significant trip, husband lubed the bars to make them easier to get in and out. Guess what. They were anti sway, until the lube. We thought we were going to have to get a New hitch cuz of the sway. Much research later found out what we Actually had and what we did wrong. We actually just have to clean the lube off. Live and learn.
mini-me is offline   Reply With Quote
Old 08-25-2013, 07:10 PM   #13
Jjs2000z's Avatar
Yes live and learn! Lol
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 08-25-2013, 08:50 PM   #14
KDHfan's Avatar
I have the 4-point Equalizer... I lube with high pressure HD grease before each trip. I've never felt any sway while towing.
I met a guy recently who told me he takes his Equalizer off his rig before he enters a campground... Because of the noise. I asked him why he doesn't grease it? He said the dealer told him to never, ever lube the WD system. Imagine his shock when I pulled out the manual and showed him where it says to do just that.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 08-26-2013, 06:56 AM   #15
Campcation's Avatar
I have the Equalizer 12k and I have to tighten the bolt a little about every third trip. It does get a little noisy if you forget to grease.
Campcation
2013 Rockwood Roo 233S
1998 Dodge Ram 2500
Equalizer 12000
Campcation Days This Year: Not nearly enough!!!!
Campcation is offline   Reply With Quote
Old 08-26-2013, 07:50 AM   #16
Platokidd's Avatar
Originally Posted by Triguy View Post
As mentioned, its necessary to lube the friction areas of the socket joints. That and a few trips will help. But, make sure to keep those socket bolts between 45 and 65 and check regularly.
Progress claims its acceptable to lube the L-brackets if noise is an issue but I prefer to use their bracket jackets instead of lube.
check bolts regularly!!! The first few times my knuckle would loosen up as well as the tilt bolt. Keep the pivot points lubed. I use mower guard graphite on the bars and L bracket. Its a dry graphite paint and embeds itself into the metal. Not messy!!
MowerGUARD™ - Graphite Undercoating for Mower Decks and Blades
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 08-26-2013, 11:37 AM   #17
Gizmo0706's Avatar
That may be worth trying! I just wrap my whole hitch head in a shopping bag before handling, containing the mess.
Gizmo0706 is offline   Reply With Quote
Old 08-26-2013, 04:04 PM   #18
Originally Posted by Jjs2000z View Post
It should be very difficult to move the sway bars in and out on the hitch. I would recommend getting the equalizer grease/lube. Also I would get the "L" bracket padding. This will quiet the majority of the noise on the hitch set up. If you have any questions let me know
X2. The sway bracket jackets are $21.00 and can be ordered at any RV dealer. They are also available at the Equalizer hitch factory store. Equal-i-zer Hitch Store
I have the bracket jackets and use their specified grease. All is quiet.
l001952119 is offline   Reply With Quote
Old 08-26-2013, 04:08 PM   #19
Jjs2000z's Avatar
Yes the sway bar jackets eliminate 90% of the hitch noise when turning
2014 stealth 2714
Old 08-31-2013, 08:44 AM   #20
My Equal-i-zer was noisy when I first got it. I finally figured out that one way to quiet it is to make sure that the bars are exactly perpendicular to the L brackets when hooked up. If not perpendicular, the bars ride more on one edge of the L brackets and make noise.
To square then, hook up with the L bracket frame bolts loose. Get a carpenters square and check the angles. Tap the L brackets until they are square. There should be enough movement to allow squaring. If you can't square them, then your bars are not parallel enough with the frame and other adjustments are appropriate.
Tighten the frame bolts and most of the noise will be gone.
joshuajim is offline   Reply With Quote
equal-i-zer, hitch
