Old 09-01-2013, 06:52 AM   #21
Platokidd's Avatar
Originally Posted by joshuajim View Post
My Equal-i-zer was noisy when I first got it. I finally figured out that one way to quiet it is to make sure that the bars are exactly perpendicular to the L brackets when hooked up. If not perpendicular, the bars ride more on one edge of the L brackets and make noise.
To square then, hook up with the L bracket frame bolts loose. Get a carpenters square and check the angles. Tap the L brackets until they are square. There should be enough movement to allow squaring. If you can't square them, then your bars are not parallel enough with the frame and other adjustments are appropriate.
Tighten the frame bolts and most of the noise will be gone.
X2
I monitor the wear on my L brackets and make sure there evenly wearing across the surfaces.
The bracket jackets sound like there nice to have but with the new style quick release L-pin there not recommend for use.
Happy campin
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Platokidd is online now   Reply With Quote
Old 09-01-2013, 10:49 AM   #22
Jjs2000z's Avatar
The sway bar jackets are recommended by equalizer. Look in the manual
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 09-01-2013, 02:48 PM   #23
Originally Posted by Platokidd View Post
X2
Happy campin
The wear may show as even because the porposing motion of the trailer while traveling which is 99% of the wear. The bars could still be riding on one edge of the L bracket during slow travel and causing the noise.
joshuajim is offline   Reply With Quote
Old 09-01-2013, 03:39 PM   #24
I had the same issue. Mine were way over tightened. Once I loosened and torqued to specification the bars were still pretty stiff and hard to move. After 5000 miles of towing things are much easier. Check the torque occasionally.
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
equal-i-zer, hitch
