Old 08-24-2014, 01:08 PM   #1
collinpr's Avatar
New Everything
I recently sold a 04 Dodge 3/4 ton 4x4 Cummins (Hi-jacker 5th hitch) and a 2009 Outback trailer.
I have upgraded to a 2014 Dodge cummins 1 ton DRW, crew cab with an 8 ft box, and a 2014 Columbus 635RL. The trailer will not be delivered until mid- Sept.
My question is how high (or approx) do I set the 5th wheel hitch in the truck ?
The hitch is a new Curt Q20, non slider (I have an 8ft box).
Thanks much for any info you can provide.
collinpr is offline   Reply With Quote
Old 08-24-2014, 03:37 PM   #2
4x4 or 2wd? The new trucks have higher bed walls so in general they do like higher settings then your old truck but it also depends on your drive. My guess would be to set on the lowest or second to lowest setting to start and when the new fiver is on, go from there.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
DocGTO is offline   Reply With Quote
Old 08-24-2014, 07:24 PM   #3
collinpr's Avatar
The new truck is a 3500 4x4 dual rear wheels.
Old 08-24-2014, 08:30 PM   #4
She's got a tap butt for sure but since you bought a new fiver, they are being designed for the newer trucks. I would say start with the low or the second to lowest setting and go from there. I'm sure someone else with more experience then me can step in and help out as well
Doc
Old 08-24-2014, 08:35 PM   #5
Campin Cajun's Avatar
Your dealer should set up the height the day you pick up your camper.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 08-24-2014, 08:40 PM   #6
True.
Doc
Old 08-24-2014, 08:41 PM   #7
Hooked up to tow the trailer should be level. I believe you should have at least 6 inches above the side walls. I use that as a rule and always had plenty of space.
Started Out With Nothing,
Still Have Most Of It Left!
jwedell is offline   Reply With Quote
Old 08-24-2014, 08:46 PM   #8
davel1971's Avatar
I have that hitch in my 2014 1 ton Chevy. Started at middle height setting. Bed clearance little to close for my comfort. Had to raise hitch to highest height. 5th wheel just a tad high in front, but not bad
David & Lynn
Old 08-27-2014, 05:40 PM   #9
Chewie's Avatar
My q20 is set at the middle bolt holesClick image for larger version
Name:	ImageUploadedByForest River Forums1409179247.170871.jpg
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
