Old 06-29-2016, 05:29 PM   #21
northstar1960's Avatar
Originally Posted by Sharon2540 View Post
New to this forum, this is my first post. I have a new 2016 F-150 super crew cab with the 6' box, 3.5 ecoboost, max tow package. Time to get something to pull. I would like owners of this type vehicle to share what they are towing currently (Brand, tt or fiver, length, weight, pin weight / hitch set ups) what experience they have had especially the problems and if they would do something different than there current set-up. Looking to make some long trips when retire in a year and maybe some short ones until then.
Thanks all.
From what i've read of other eco boost owners you good to go on anything you like
northstar1960 is offline   Reply With Quote
Old 06-29-2016, 09:38 PM   #22
I have the '16 SCREW 4x4 3.5 EB w/3.55. I'm towing a 282RK Hemisphere under 7K dry and 35'. When I towed it home from the dealer it was a little harrowing and I was worried I got too much camper and was fearful about getting on the road again. Today I am a happy camper after getting my setup dialed in, took a little trial and error getting my EAZ Lift WDH adjusted perfectly and added an extra sway control bar. For the rear suspension I had a set of super springs installed to help with sag. My truck came with 18" 116T tires that I inflate to 46 psi for towing. After doing this, when big rigs pass me on the interstate I don't hardly notice driving 60-65 mph. I believe the super springs helped with the stability and sway as they claim to do.
Seachaser186 is online now   Reply With Quote
Old 06-29-2016, 10:47 PM   #23
Sky&Scuba
kendive's Avatar
Nice Truck. I have done a few mods to mine. 2" Autospring Lift front and back 33" KO2's Tires, I installed the Amp Research Running Boards. I also swapped out the rear FX4 shocks and installed the Bilstein 5100's. I installed Ride Control Air Bags with the Wireless One Pump Kit.
I have that keyless start and disabled the double honk if you get out of the truck with the key in your pocket. I also wired up where I can turn on the mirror spots lights at anytime. No more cutting off at 7mph.
I really like the power of the 3.5 Eco Engine.
2015 F150 3.5 EcoBoost Lariat FX4 502A 3.55 Gears Max Tow KO2 Tires
2017 Grand Design Imagine 2150 RB / Traded in Catalina 253RKS
kendive is offline   Reply With Quote
Old 06-30-2016, 09:00 AM   #24
MilCop4523's Avatar
Originally Posted by kendive View Post
I noticed you use Tow Mode on you 14 F150. When in tow mode doe the 2014 F150 down shift for you to assist in braking?
in my 2013 the tow haul mode allows the truck to engine brake down steep hills like 2 weeks ago. it took it from 4th to 2nd as the grade was extreme.
The Tow/Haul Mode: When do You Use It? « East Portland Blog
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 07-02-2016, 12:06 AM   #25
Name:	ImageUploadedByForest River Forums1467432286.483650.jpg
2012 FX4, 3.5 Ecoboost , 2016 26DBH Cherokee Greywolf. Pulls great. No issues.
Mofire75 is offline   Reply With Quote
Old 07-02-2016, 12:16 PM   #26
acadianbob's Avatar
The two things that I would pay most attention to are:
1) Your payload rating. You can pretty easily consume 600 to 800 pounds of payload before you ever hook up your trailer. People, pets, hitch, accessories, stuff in the bed. Also, the dry trailer weights are a starting point. Most people are 1,000 to 1,500 pounds MORE when loaded. This will add about 150 to 200 pounds more on tongue weight.
2) Trailer length. The "old saw" is divide your wheelbase by 5 and the result is the approximation of the maximum trailer length you should pull. So, 145" wheelbase equals 29 feet of trailer. If you pull "Out West" or in the mountains, I'd pay attention to this factor. The trailer is a huge sail back there.
Do you calculations and make your decisions based on facts. Just because someone else "made it alive" with a bigger trailer doesn't mean it's a good idea.
http://i421.photobucket.com/albums/pp297/acadianbob/IMG_2757.jpg
2012 F150 FX4 Ecoboost, 2016 Surveyor 274BHS
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
acadianbob is online now   Reply With Quote
Old 07-04-2016, 09:58 AM   #27
Is the trailer length vs wheel base ratio based on coupler to rear bumper? My weights are in line as long as I don't over do it. I have 1830 payload w/ 6900 dry weight. My TV has a GVWR of 7000 and total limit is 16100.
Old 07-04-2016, 10:55 PM   #28
I have a 2016 F150 screw with a 2.7....tows great.....behind my 364TS ����
JLud is offline   Reply With Quote
Old 07-20-2016, 04:53 PM   #29
We are running a 2015 f-150 v-6 eco-boost with Max trailer towing package, pulling a forest river wildwood 282rk. Have been in South Dakota and Pennsylvania mountains and lowlands and I do not think I could get a better package. I average 10mpg. Pulling and 23mpg not. And pass eighteen wheelers on grades...I am very happy with this set up.
Travelingcarl is offline   Reply With Quote
Old 07-20-2016, 06:48 PM   #30
Carl, I take that is the Heritage Glen. I have the Hemisphere twin, love the camper. That is my setup pic in the earlier post. Glad to hear your positive feedback on your experience.
trailer
